Register to reply
Parameterizing A Circle Projected onto a Plane
by TranscendArcu
Tags: circle, parameterizing, plane, projected
Share this thread:
TranscendArcu
#1
Nov26-11, 03:57 PM
P: 288
Find a vector function that parameterizes a curve C which lies in the plane x-y+z=2 and directly above the circle x2 + (y-1)2 = 9
3. The attempt at a solutionSo, in order to parameterize the circle, I simply use x=cos(t), y = sin(t) with some adjustments. Namely, I let x=3cos(t) and y=3sin(t)+1. Then, to determine how the z-coordinates of this curve change according to x,y I use the definition of the plane. So I have z=2-x+y, which I convert using my parametric defintions for x,y.
I have, z=3-3cos(t)+3sin(t). Therefore, my parameterized curve is,
<3cos(t),3sin(t)+1,3-3cos(t)+3sin(t)>
Right?
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
I like Serena
#2
Nov26-11, 06:04 PM
HW Helper
I like Serena's Avatar
P: 6,187
Looks good.
But... is it always above the circle?
TranscendArcu
#3
Nov26-11, 08:12 PM
P: 288
So I just drew myself a little sketch. Basically I have plane and, beneath it, a cylinder which extends upwards, whose base represents the circle. The intersection of the cylinder and the plane should be the projection of the circle onto the plane, right? In this case, I can't see how the projection could be anywhere else besides over the circle.
As an aside, the vector projection of a onto b is given as follows:
((b [dot] a)/|a|) * a/|a|.
Is it possible to use the idea of projections along with dot products to solve this problem?
I like Serena
#4
Nov26-11, 08:27 PM
HW Helper
P: 6,187
Quote Quote by TranscendArcu View Post
Consider t=-pi/4.
Is the corresponding point above or below the circle?
This is the formula for projection onto a line.
It doesn't work for projection onto a plane.
Anyway, you still need a parametrization.
Your method is just fine.
The only catch is that the curve is not entirely above the circle (assuming the problem does make this fine distinction).
TranscendArcu
#5
Nov26-11, 08:37 PM
P: 288
OH! I see what you mean now. So presumably I need only calculate a z-coordinate for above/below orientation:
z=3-3cos(t)+3sin(t), where t=-pi/4
z=3-3sqrt(2).
So I understand that this point is below the xy-plane, but I don't understand how this impacts the parametrization. Does it change how I am allowed to define t? If the intersection of my cylinder with the plane is still the projection, what difference does "above" or "below" make?
I like Serena
#6
Nov26-11, 08:42 PM
HW Helper
P: 6,187
Well, as I interpret the problem (and I may be wrong), it asks for a parametrization that is "above" the circle.
So I think you're supposed to limit the range of t, such that the curve is indeed "above" the circle.
But perhaps I'm being too nit-picky. You tell me.
Still, it is good practice...
Register to reply
Related Discussions
Circle in plane parameterization Calculus & Beyond Homework 14
Block Projected up Plane with Spring atop Introductory Physics Homework 2
X,Y Coordinates Circle, Different Plane General Math 3
Projected-projected einstein equation General Physics 1
Circle Plane Geometry Introductory Physics Homework 2
