Solving Bullet Impacts a Block: Force, Velocity & Distance
The discussion revolves around a physics problem involving a bullet impacting a block, specifically focusing on concepts of momentum, force, and friction. The scenario describes a 50 g bullet traveling at 50 m/s colliding with a block 2.0 m away, with a coefficient of friction of 0.30, and assumes a perfectly inelastic collision.
  • Participants explore the relationship between momentum and the velocities of the bullet and block post-collision, questioning the need for the block's mass. There are discussions about using the coefficient of restitution and the implications of friction on momentum conservation. Some participants express uncertainty about calculating acceleration and the force exerted by the bullet on the block.
The discussion is active, with participants raising various points about the assumptions in the problem, such as the need for additional information regarding the block's mass and the specifics of the collision. There is a recognition of the complexities involved in determining the force of the bullet on the block without knowing certain variables, and some guidance has been offered regarding the use of conservation of momentum and kinetic energy.
Participants note the potential incompleteness of the problem statement, specifically the absence of the block's mass and details about the collision dynamics, such as penetration depth or time of impact. There is also mention of the challenges faced by those in lower-level physics courses in applying these concepts.
Merlinnair
A 50 g bullet at 50 m/s hits a block 2.0 m away. The coefficient of friction is 0.30. What is the force of bullet on the block, the velocity of the block and bullet and distance traveled by the block? Assume this is a perfectly inelastic collision.
Known: m_b = .0050kg
v_b = 50. m/s
d_b = 2.0 m
μ = 0.30
p_1 = p_2
F = ma
μ = -a/g
Fd=1/2mv^2
A) 0.30 = -a/9.8
I feel like this isn't right for some reason...would this give me the correct acceleration?
B) (.0050kg)(50 m/s)=(m_1 + m_2)v
Since it's perfectly inelastic, can't I assume that v is the same for the block? Is that how I'd find m2?
C) I would be able to solve for distance once I have the velocity.
I think you should consider the coefficient of restitution and what it means in this situation which is a perfectly inelastic collision with friction.
The question statement seems incomplete to me. Shouldn't we be given the mass of the block? And "the force of the bullet on the block" has no meaning without knowing the depth of penetration or the time for the bullet to come to a halt within the block.
I don't think you need to know the mass of the block, my following explanation may give away too much. In a perfectly inelastic collision, coefficient of restitution is zero. Also momentum is only conserved if there is no friction. There is friction here. I only stated basic principles associated with this problem, but I believe it is enough.
I am looking forward to your elaboration of the solution with great anticipation :smile:
Sorry, I may be forgetting a variable, as I don't have the question with me. Do I need the acceleration, or can I find the force by solving for kinetic energy?
And, I don't know what the coefficient of restitution is...
If m_2 is one of the given variables, then would my work for finding velocity be correct?
To find distance I was going to use 2ad = vf2 - vi2
But I still have the issue of finding acceleration.
And assuming I do have the mass of the block, how do I find the force of the bullet on the block?
If m_2 is one of the given variables, then would my work for finding velocity be correct? If so, then I should be able to find the distance myself...
F = ma = -f = -μmg
So a = -μg
And then I plug a back into ma to find force...right?
If you know the mass of the block then you can find the velocity of the bullet+block the instant after the bullet becomes lodged in the block by conservation of momentum. After that the block and bullet move together as a single object, sliding with friction on the surface. The usual accelerated motion techniques then apply.
As for the force of the bullet on the block, I think you'll still need to know something else about the particulars of the collision, such as the depth of penetration or the time for the bullet to come to a stop within the block.
I'm in a pretty low level physics class, I'm not even sure how to use them if I had those variables. Could I simply neglect that fact that the bullet embeds itself?
Part of the problem statement was to find the "force of bullet on the block". I don't know how you can do that without knowing some details about the collision. Knowing, for example, the initial and final velocities for the bullet and either the distance or time over which that velocity change happened, you can determine the average acceleration that the bullet experienced. That would give you the force (F = M*A).
  • · Replies 33 ·
