| New Reply |
Simple question about time dilation in accelerated reference frames |
Share Thread | Thread Tools |
| Nov26-11, 05:40 PM | #1 |
If one wants to calculate the elapsed time from the perspective of an object A moving at velocity, v, for time, t, relative to a stationary object B, all you have to do is calculate:
[tex] \int_{t_o}^{t_f}\frac{t}{\gamma} [/tex] Of course, [tex] \gamma [/tex] has no dependence on t because v is constant, so we get: [tex] \int_{t_o}^{t_f}\frac{t}{\gamma} = \frac{t_f-t_o}{\gamma} [/tex] My question is if this can be plainly extended to accelerated reference frames where the velocity is changing. In other words is this equation valid for calculating elapsed time when velocity varies : [tex] \int_{t_o}^{t_f}\frac{t}{\gamma(t)} [/tex] where [tex] \gamma(t) [/tex] is the lorentz factor at time t? I will try to make this more clear later. Any insight is appreciated. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov26-11, 08:33 PM | #2 |
Recognitions:
It doesn't work for an accelerated frame.
It does, however, work as the formula for the elapsed proper time along an accelerated worldline, where the time and velocity of the accelerated object are relative to an inertial frame. The quantity calculated is a geometrical invariant (ie. an accelerated frame would calculate the same value, except the formula is more complicated in an accelerated frame). The elapsed proper time along any worldline defines what we mean by an ideal clock travelling on the worldline. |
| Nov27-11, 02:34 AM | #3 |
If we have the case of one dimensional constant proper acceleration and identify:
t = proper time for home stayer tau = proper time of the traveler alpha = constant proper acceleration Then we get: [tex]\Large \tau=c \;\;{\it arcsinh} \left( {\frac {t\alpha}{c}} \right) {\alpha}^{-1}[/tex] and [tex]\Large t=c \;\; \sinh \left( {\frac {\tau\,\alpha}{c}} \right) {\alpha}^{-1} [/tex] |
| Nov27-11, 06:13 AM | #4 |
Recognitions:
| Nov27-11, 11:11 AM | #5 |
| Nov27-11, 11:41 AM | #6 |
Recognitions:
| Nov27-11, 12:34 PM | #7 |
I think in case of one dimensional constant proper acceleration we have: [tex]\Large v_{{t}}=\sqrt {{\frac {{t}^{2}}{{t}^{2}+{\alpha}^{-2}}}}[/tex] If we plug this into the Lorentz factor we get the following integral: [tex]\Large \int _{0}^{{\it time}}\!\sqrt {1-{\frac {{t}^{2}}{{t}^{2}+{\alpha}^{-2 }}}}{dt}[/tex] Which becomes (if we assume c is not equal to 1): [tex]\Large \tau=c \;\;{\it arcsinh} \left( {\frac {t\alpha}{c}} \right) {\alpha}^{-1}[/tex] |
| Nov27-11, 12:37 PM | #8 |
Recognitions:
| Nov27-11, 01:07 PM | #9 |
Atty, if you think I am wrong perhaps you could construct the integral the way you think is right without using gamma?
| Nov27-11, 01:27 PM | #10 |
Recognitions:
For an accelerated worldline in an accelerated frame, we'd integrate the root of ds2=guvdxudxv, exactly the same, except that ds2≠dt2-dx2, since guv≠diag(1,-1,-1,-1) in an accelerated frame. |
| Nov27-11, 01:53 PM | #11 |
I think I misused the term accelerated reference frame. An "accelerated worldline described in an inertial coordinates" was the situation I was wondering about. Sorry about that!
Anyway, I'm happy intuition is right in this case. Wikipedia wasn't making that connection very explicit to me. Passionflower, thanks or those equations :) and the explanations of them. Yeah, the case of constant proper acceleration is all I was really interested in. |
| New Reply |
| Thread Tools | |
Similar Threads for: Simple question about time dilation in accelerated reference frames
| Simple question about inertial frames of reference | Special & General Relativity | 42 | ||
| A question about reference system and time dilation | Special & General Relativity | 8 | ||
| Time dilation and non inertial reference frames. | Introductory Physics Homework | 0 | ||
| Time dilation on accelerated reference frames | Special & General Relativity | 5 | ||
| Time dilation and expansion in accelerated motion | Special & General Relativity | 70 | ||
