A solenoid where radius length?
The discussion revolves around the characteristics and equations related to solenoids, particularly focusing on scenarios where the radius is much greater than the length. Participants explore the implications of this configuration on magnetic field calculations and seek guidance on relevant equations, especially for magnetic fields outside the solenoid and their relation to electric motors.
  • One participant questions the applicability of existing solenoid equations when the radius significantly exceeds the length, suggesting a need for alternative approaches.
  • Another participant proposes using the Biot-Savart Law for calculating the magnetic field of a steady current, noting the complexity of integration in certain cases.
  • It is mentioned that the magnetic field inside a non-ideal solenoid (with greater girth than length) will be less uniform and non-zero outside, contrasting with the ideal infinite solenoid scenario.
  • A participant shares their experience with a paper that provides exact solutions for solenoids, indicating that these solutions involve complex mathematical functions.
  • Questions arise regarding the definition of "long" in relation to the length and radius of a solenoid, with participants seeking a clearer guideline or ratio for these dimensions.
  • Another participant notes that the standard equation for the magnetic field inside a solenoid does not specify a length or radius, prompting further inquiry into the necessary conditions for these parameters.
Participants express differing views on how to approach the problem of solenoids with a larger radius than length, with no consensus on a definitive guideline or ratio for the dimensions. The discussion remains unresolved regarding the best methods for calculating magnetic fields in these scenarios.
Limitations include the lack of clear definitions for "long" in relation to solenoid dimensions, and the complexity of deriving magnetic field equations for non-ideal solenoids. The discussion also highlights the need for familiarity with advanced electromagnetism concepts to apply certain equations effectively.
infamous_Q
i've found a lot of equations and relations about solenoids where the lengh tis always much greater than the radius, but what if the radius was much greater than the length?
PS. also does anyone know an equation that could help me figure out the magnetic field strength outside a solenoid? or any equations relating to an electric motor would be helpful too.
thanx!
I guess in principle the magnetic field of a steady current can always be calculated from the Biot-Savart Law:
[tex]\mathbf{B(r)} = \frac{\mu_0}{4\pi}I\int{\frac{d\mathbf{l'} \times \mathbf{\hat{r}}}{r^2}}[/tex]
However, the integration may not always be...nice. Or even possible. In my electromagnetism text, the example in which the magnetic field directly above the centre of just one circular loop of current-carrying wire was laborious enough. The field of a solenoid was deduced much more easily using Ampere's law:
[tex]\oint{\mathbf{B}\cdot d\mathbf{l} } = \mu_0 I_{enc}[/tex]
This requires the use of appropriate Amperian loops in various regions...if you haven't encountered these equations from magnetostatics before...don't try to use them without learning more first about them.
As for a solenoid of much greater "girth" than length...it is far from "ideal" in the sense that the field will be less uniform inside and decidedly non-zero outside (a straight field inside and zero outside is the ideal achieved by an infinite solenoid that "very long" solenoids attempt to approximate). I don't have any specific formulas describing this field offhand.
My first guess would be to treat it as a loop or coil rather than a solenoid. But then it's been a while since I've tackled these kinds of problems.
I wrote a paper on this a few years ago, with an exact solution for any kind of solenoid. It turns out that the solutions are quite complicated, and involve modified Bessel functions.
The standard first-year approximation for the field inside a solenoid, provided it is "long" and you're not looking too near the "walls" is:
[tex]B = \mu_0 n i[/tex]
everywhere inside the solenoid, where [tex]n[/tex] is the number of turns per unit length, and [tex]i[/tex] is the current.
but how long is how long
is there a ratio between the two, length and radius, that will give a definition of the size.
Dimensions of a Solenoid
In the the equation describing a solenoid, B=unI, it does not specify a length or radius and on things i have read it says that the radius just has to be long compared to the radius. i was wondering if there is a better guideline like a ratio to explain this.
