Is There Upthrust on a Smooth Object on a Smooth Ocean Floor?
The discussion centers on the concept of upthrust experienced by a perfectly smooth object resting on a perfectly smooth ocean floor. Participants conclude that without water beneath the object, there is no upward pressure to create upthrust, resulting in only downward forces from the water above. The notion of molecular space is also explored, suggesting that if the object and floor are truly smooth, they may effectively become one, negating any potential for upthrust. The conversation highlights the critical relationship between pressure, surface smoothness, and buoyancy.
  • Understanding of fluid dynamics principles
  • Knowledge of pressure and buoyancy concepts
  • Familiarity with molecular interactions in fluids
  • Basic physics of forces and equilibrium
  • Research the principles of buoyancy in fluid mechanics
  • Explore the effects of surface tension on fluid interactions
  • Study the role of molecular spacing in fluid dynamics
  • Investigate the mathematical models of pressure distribution in fluids
Students of physics, fluid dynamics researchers, and anyone interested in the principles of buoyancy and pressure in fluids.
ponjavic
would there be an upthrust or not if a perfectly smooth object was on a perfectly smooth ocean floor?
I expect that since there is no water beneath the object there is no pressure to provide an upthrust, there would only be pressure above the object creating a downward force!?
If you're saying there is no room for even a molecule to get between the object and the ocean floor, then the object is actually a part of the ocean floor. And in that case, I think you're right - the 'object' would be held down by the water pressure.
and if there would be room for just one molecule?
Does the fact that they are perfectly smooth mean that there is no room for the molecules?
10K
11K
  • · Replies 62 ·
