Is My A-Frame Structure at Risk of Buckling or Bending?
  • Thread starter Thread starter Fugro
    Analysis Member
The discussion centers on analyzing an inverted 'A-frame' structure with members measuring 1.22 m and subjected to a uniformly distributed load (UDL) of 6580 N/m. The angle between the members and the horizontal is 5 degrees, and the footings are securely bolted. The user seeks confirmation on whether the load components can be resolved into those causing bending and buckling, specifically identifying that the perpendicular component causes bending while the axial component leads to buckling. The consensus confirms that this approach is valid for structural analysis.
  • Understanding of structural mechanics
  • Knowledge of load analysis techniques
  • Familiarity with buckling theory
  • Experience with bending moment calculations
  • Study the principles of structural stability in A-frame designs
  • Learn about calculating bending moments in structural members
  • Research buckling analysis methods for slender structures
  • Explore software tools for structural analysis, such as SAP2000 or ANSYS
Civil engineers, structural designers, and students studying mechanics of materials will benefit from this discussion, particularly those involved in analyzing and designing frame structures under load.
Fugro
Hi,
I have a design using a simple 'inverted v' frame . Each member is 1.22 m long and sees a UDL on it, acting downward(6580 N/m). The angle between the members and the horizontal is 5 degrees. and both footings are bolted firmly to the horizontal.
I wish to analyse and confirm that the members will not buckle or fail due to bending.
Can I resolve the components of the load (6580*1.22 = 8030N) into those perpendicular to the members and those along the member, and assume that it is the component perpendicular to the member causing bending, and the component along the members length which will cause buckling?
This seems all way to easy - i am sure that some forum people may be able to help me do a more advanced and accurate analysis. Any help will be appreciated.
Thanks
Fugro said:
Can I resolve the components of the load into those perpendicular to the member and those along the member, and assume it is the component perpendicular to the member causing bending, and the component along the member length that will cause buckling?
Yes.
  • · Replies 28 ·
