Register to reply
Entropy involving current and resistance question
by jrklx250s
Tags: current, entropy, involving, resistance
Share this thread:
jrklx250s
#1
Nov28-11, 11:38 PM
P: 15
A current of 10A is maintained for 1s in a resistor of 25Ω while the temperature of the resistor is kept constant at 27C. This resistor is thermally insulated with a mass of 10g. If it has a specific heat of 836 J/kg*K. What is the entropy change of the resistor? Universe?
2. Relevant equations
3. The attempt at a solution
Ok so if the wire is thermally insulated at a constant temperature of 27C, Q=0 therefore
W=0 because it is isothermal and adiabatic
So if entropy is
TdS= dU - dW
so ΔS = 0J/K?
However this is wrong...the answer is 5.78J/K and im confused at to how they got this... any suggestions?
Phys.Org News Partner Science news on Phys.org
'Office life' of bacteria may be their weak spot
Lunar explorers will walk at higher speeds than thought
Philips introduces BlueTouch, PulseRelief control for pain relief
rude man
#2
Nov29-11, 01:57 AM
HW Helper
Thanks
PF Gold
rude man's Avatar
P: 4,914
I don't see how a resistor can have a current put thru it, be thermally insulated and maintained at constant temperature. Anybody?
jrklx250s
#3
Nov29-11, 01:04 PM
P: 15
Yea exactly, thats why I'm confused...being thermally insulated Q=0 and being held at a constant temperature it is isothermal. Therefore this is adiabatic and isothermal so...if the ΔS=ΔQ/T and there is no heat change well then there is no entropy change? Clearly I'm wrong though because the answers is 5.78 J/K.
rude man
#4
Nov29-11, 02:03 PM
HW Helper
Thanks
PF Gold
rude man's Avatar
P: 4,914
I think we've been careless in reading the question.
Here's the situation: the resistor is packaged inside an insulator. The INSULATOR has c = 836 SI units and mass = 10g.
The resistor clearly suffers no change in entropy because no heat flows to the resistor (the energy flowing to the resistor is work, as represented by a generator required to furnish the electricity).
But the insulator does receive heat Q from the resistor, and will heat up (increase its temperature T) over the 1 sec time interval. So the insulator increases its entropy per ΔS = ∫dQ/T. If we ignore loss of heat to the environment, that will be the increase in entropy of the universe as well.
T(t) of the insulator = T0 + (P/C)t where P = i^2*R, C = c*10g/1kg and t = time after starting the current.
i = 10A, R = 25 ohms, and T(t=0) = T0 = 300K (assume insulator is at T=300K before current is applied).
dQ(t)/dt for the insulator = CdT(t)/dt so dQ(t) = CdT(t) so now you can perform the integral.
Careful of the difference between heat capacity C and specific heat c. C = 0.01c here since the insulation has mass = 10g.
I'll try to come up with the actual answer while you work the problem and will let you know if I got the correct answer.
jrklx250s
#5
Nov29-11, 02:19 PM
P: 15
Ah wonderful. Thanks for your help here now I get it. So the INSULATOR actually increases its entropy which is done by its temperature change which is T(t) = 300K + (10A^2*25Ω)/(8.36 J/K) = 599K
Now the Entropy change of the resistor inside the insulator is ΔS = ∫CdT/T = 8.36*ln(599K/300K) = 5.78 J/K
Thank you rude man :P !
rude man
#6
Nov29-11, 02:49 PM
HW Helper
Thanks
PF Gold
rude man's Avatar
P: 4,914
Quote Quote by jrklx250s View Post
No, the resistor entropy does not change, because no heat flowed into it (I know it sounds goofy, but you have to interpret "heat" very strictly as that energy which flows by virtue of a difference in temperature. The resistor receives no heat flow; its increase in internal energy comes from the work done by, for example, an external generator used to supply its electrical energy.
So: ΔS of resistor = 0
ΔS of universe = 5.78J/K. Thanks for saving me the trouble of getting the answer.
Register to reply
Related Discussions
Question about current and resistance Introductory Physics Homework 5
Quick question on resistance&current in a sheet Advanced Physics Homework 0
Need help with a question involving heat engines, the carnot cycle and entropy. Advanced Physics Homework 3
Resistance and current question Introductory Physics Homework 5
Question about Current and Resistance General Physics 7
