| Thread Closed |
Vinegar and Soda |
Share Thread | Thread Tools |
| Dec6-04, 12:44 AM | #1 |
Vinegar and Soda
Recently, I mixed vinegar and soda water together in a plate, but the result was confusing. Since soda water contain sodium silicate and sodium ash, the result should be soluble, as sodium salts always dissolve in the water. However, in the experiment, I get some white pieces which can't dissolve in the water. What is it?
| Dec6-04, 03:44 AM | #2 |
Vinegar has some preservative compounds, I think the white pieces come from it. You wanted to do a neutralization, I suppose, I recommend that you do it with real chemicals to avoid side reactions (like those white pieces you saw in your experiment). You may be right about sodium salts' solubility, but consider that vinegar acid may produce silicate acid, which is poorly soluble in water.
| Dec6-04, 10:29 PM | #3 |
| Dec8-04, 01:21 AM | #4 |
Vinegar and Soda |
| Dec8-04, 01:24 AM | #5 |
Anyway, thanks for your advice. |
| Dec8-04, 02:55 PM | #6 |
It is clear I think; silicate acid is very sparingly soluble in water, so white precipitates will form. Maybe the ones you saw were just silicate acid, who knows? You may try treating this solution with a base, and report if these precipitates disappear. Then you can conclude that this is probably silicate acid.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Vinegar and Soda
| Vinegar and stomach acid pH | Biology | 26 | ||
| bleach and vinegar | Chemistry | 4 | ||
| Vinegar and steel | Chemistry | 3 | ||
| Balancing Vinegar and Baking soda equation | Biology, Chemistry & Other Homework | 2 | ||
| Vinegar to methanol? | Chemistry | 13 | ||
