Don't understand by the arrangement of the capacitors in the diagram.
  • Thread starter Thread starter Sanosuke Sagara
    Capacitors Diagram
The discussion revolves around understanding the arrangement of capacitors in a circuit diagram connected to a battery. The original poster expresses difficulty in interpreting the setup and seeks clarification on the configuration of the capacitors and the implications of the battery connections.
  • Participants explore the arrangement of capacitors X, Y, and Z, with some suggesting that capacitors Y and Z are in parallel and in series with capacitor X. Questions arise regarding the interpretation of the battery connections, specifically whether the batteries are separate or combined, and the meaning of any dotted lines in the diagram.
Participants are actively engaging in clarifying the arrangement of the capacitors and the battery setup. Some guidance has been offered regarding the series and parallel connections, but there remains uncertainty about the visual representation in the diagram and the implications of the battery configuration.
There is mention of a diagram that is not visible to all participants, leading to potential misunderstandings about the connections and the presence of dotted lines indicating battery separation. The original poster has attached a diagram, but its clarity is questioned by others.
Sanosuke Sagara
I have think for this question very hard but still I cannot get the correct answer.I need somebody to help me figure out how the capacitors in the diagram are arranged.
I hope that someone will reply me back as soon as possible.I have my question and diagram in the attachment followed.Thanks for anybody that spend some time on this question.
capacitor y and z are parrallel to each other...and together are in series with x
Thanks for your help,but,I still want to know whether the dotted line between the battery means that the battery are separated equally.
what do u mean by separated?
Diagram shows three capacitors X ,Y , Z are connected to a 6.0 V battery as shown.
by this, do you mean the source is one 6.0 V battery? or each battery is 6.0 V?
well.. just take these 2 batteries and consider it as one with voltage equal to the sum of the voltage of the two batteries. Say, the voltage of each battery is 6.0 V, then the source supplies 12.0 V potential difference.
Since they are all connected in a circuit, i don't think you can separate the source that supplies energy to capacitor Y, Z and X
as tigger said, I think that the batteries are two separate batteries connect in series with the rest of the circuit (so you can add their voltages in this case)
I don't see any dotted lines. But that could be because the monitor I'm using is a little fuzzy. If the conductor connecting the two batteries is dotted, that means that there are more cells in the battery than are shown.
I don't see any dotted line either...and it is clear on my screen :-/
  • · Replies 20 ·
  • · Replies 62 ·
