"Whiskey Stones" - ice, stone, steel: which is best??
by brennantaylor
Tags: heat capacity, ice, temperature and heat, whiskey
brennantaylor
brennantaylor is offline
#1
Nov30-11, 10:39 PM
P: 1
The conundrum:
I'd like to purchase the most effective cooling item for my evening dram of scotch, or Manhattan bourbon, or Black Label, or... Where was I? Seriously, I am intrigued by the growing popularity of "whiskey rocks" - an item to replace ice - and am curious about both the science and marketability behind them. The basic idea is that a cube of glass, soapstone, or steel keeps the drink cold like ice cubes but does not melt and spoil the whiskey taste.
My main question:
Which material will keep my drink at the lowest temperature for the longest - glass, soapstone, or steel? And, more importantly, will this material cool my drink to a temperature that is close enough to the temperature of an ice-cooled drink.
Assume that the material can sit in the freezer for days (i.e. the time required in cooling is irrelevant). Assume for simplicity that cubes of each material have the same mass and surface area (though, that's a fiction).
Thoughts:
I'm working it out now, but haven't used these equations in almost 10 years. I mainly figured that it would also be an enjoyable headscratcher for PFers to discuss!
My initial hunch is that nothing gets my drink nearly as cool as water (4.186 J/gK Degree heat capacity) because only soapstone gets the closest (0.98 J/gK). But, if that turns out to be true, I just have to figure out if soapstone cools it enough to drink with pleasure, or if it's just a matter of accepting some ice-melt...
Cheers!
Phys.Org News Partner Physics news on Phys.org
A 'quantum leap' in encryption technology
Using antineutrinos to monitor nuclear reactors
Bake your own droplet lens
Simon Bridge
Simon Bridge is online now
#2
Dec1-11, 06:22 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 11,121
Welcome to LQ and good on you for explaining your understanding.
The problem is to remove unwanted heat from your drink, but not too much - so you put something cold in it. So you want something that will draw off a lot of heat for it's size. You also want the drink to stay cool for the amount of time that you are going to drink it over and without spoiling your enjoyment by, say, weakening the flavor.
So you seem to be thinking the right way about this.
One approach is to put the ice in a container - say, put water in a small sealed bag and freeze it - with the drawback that the container may act as a thermal insulator. You can sit your drink in a metal pan sitting on a bed of ice. If you use something with a smaller heat capacity than water, you need proportionally more of it - and maybe a more irregular shape since contact area related to the rate of cooling.
It's actually a nice experiment for HS or junior college.
gneill
gneill is offline
#3
Dec1-11, 02:56 PM
Mentor
P: 11,453
Water has one of the highest thermal capacities per unit volume, a high heat of fusion (melting), mediocre thermal conductivity in solid form, essentially neutral in taste, and is non-toxic. Almost the ideal material! The problem is that you want to avoid the melted water diluting things.
Copper has a very high heat conductivity, but a lousy heat capacity (per unit mass). Solubility of copper could be an issue, as it will lend a metallic taste to things, and too much metal is unhealthy.
Gold is essentially inert, non tarnishing, and low toxicity (have a shot of Goldschläger!)
So go for the Yuppie market. A gold-plated hollow copper capsule mostly filled with water (mostly so that there's room for ice expansion). The water provides the staying power of water ice, the copper an initial fast heat absorption for quick cool-down, and the gold renders it safe, good looking (mmm, shiny gold in a beautiful amber liquid in a nice cut crystal glass) and expensive. Perfect Yuppie bait.
Simon Bridge
#4
Dec1-11, 04:07 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 11,121
Good idea - I want one already ... only cast mine in the shape of an apple, and put a kappa on it ;)
snowghost
snowghost is offline
#5
Dec3-11, 03:25 PM
P: 1
Quick question, does the phase transition of the ice melting help or hinder the cooling process? If I remember right, it helps with the chilling effect. And if so, will insulating the ice in any material ( I like the gold plated copper idea) hinder this?
gneill
gneill is offline
#6
Dec3-11, 03:36 PM
Mentor
P: 11,453
Quote Quote by snowghost View Post
Ice to water phase transition takes a relatively enormous amount of energy, and is a major contributing factor to the cooling effect. Placing the ice in a container with high thermal conductivity (and copper's is quite amazing!) will not have a significant effect unless the container walls are made ridiculously thick for the application. A few angstroms of gold plating isn't going to hinder things either.
sophiecentaur
sophiecentaur is online now
#7
Dec3-11, 05:16 PM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,399
Why not just keep the Whiskey and glasses in the fridge? But what a waste of a good drink. The best Malt whiskey tastes much fuller if you drink it at room temperature.
You'll be talking about mixing it with Coke or Canada Dry next. Yeccch!
Now, Vodka straight from the freezer can be an experience.
gneill
gneill is offline
#8
Dec3-11, 05:26 PM
Mentor
P: 11,453
Quote Quote by sophiecentaur View Post
So the obvious solution is either a walk in fridge, or better yet, REALLY good air conditioning in the lounge.
Ah yes, the experience of waking up at 3:00 a.m. on the kitchen floor with a pounding headache and wondering how the truck managed to get in through the patio door, hit you, and depart thought the dining room without disturbing the china cabinet, or the cat.
sophiecentaur
#9
Dec3-11, 05:29 PM
Sci Advisor
PF Gold
P: 11,399
I didn't suggest a litre of Vodka - just a half tumbler. You youngsters have no self restraint.
Simon Bridge
#10
Dec3-11, 05:31 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 11,121
Depends what you call "room temperature" ... at 29degC it's not so great.
Also depends what you call "whiskey" - I've seen some murky lighter-fluid...
Also - if you keep the bottle and the glasses in the fridge, well some people have small fridges, and the point is to keep it cold after removal.
But nice idea. After all, the other idea is not to spoil the flavor and ice will numb the taste-buds hey ho. I sometimes like bourbon on the rocks with a sprig of mint on a sticky evening - the way the flavor changes as the ice melts is part of the experience.
For keeping cool without watering, I still say put ice in a bowl, put a metal bowl over the top, put glass of drink in the metal bowl - keep it next to your chair. Should keep a regular drink around 4degC.
But for the people who like the idea of a couple of gold-plated sphere's in their drink:
http://www.imdb.com/title/tt0111524/
Simon Bridge
#11
Dec3-11, 05:34 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 11,121
Quote Quote by gneill View Post
That's a walk in fridge... oh right...
Ah yes, the experience of waking up at 3:00 a.m. on the kitchen floor with a pounding headache and wondering how the truck managed to get in through the patio door, hit you, and depart thought the dining room without disturbing the china cabinet.
Yeah I get abducted by extra-terrestrials after drinking heavily too ...
How far can this thread degenerate?
gneill
gneill is offline
#12
Dec3-11, 05:38 PM
Mentor
P: 11,453
Quote Quote by Simon Bridge View Post
That depends upon what kinds of degenerates we are.
sophiecentaur
#13
Dec3-11, 05:50 PM
Sci Advisor
PF Gold
P: 11,399
No wonder the spllelling is so bad on this forum.
gneill
gneill is offline
#14
Dec3-11, 06:05 PM
Mentor
P: 11,453
And here I thought it was performance art.
alysdexia
alysdexia is offline
#15
Sep8-12, 05:48 PM
P: 7
deep (or wide and broad and tall), not thick—all metals are thick, and clouds are thin.
K^2
K^2 is offline
#16
Sep8-12, 06:28 PM
Sci Advisor
P: 2,470
alysdexia, you don't really want to over-cool either. If ice starts forming on whatever you dropped in, it's not good. The brilliance of using ice is because it has the phase transition exactly where you want it. So I really have to go with gneill's original suggestion. Just seal ice in a container. You have every advantage the ice brings and no water in your drink.
alysdexia
#17
Sep8-12, 08:10 PM
P: 7
K^2, your objection holds no whiskey. All cubes come from the freezer and are the same temperature. Whatever frost on one that comes out of solution should on others also. And it's a temporary problem as frost only stays when the media are still.
russ_watters
russ_watters is offline
#18
Sep8-12, 09:40 PM
Mentor
P: 22,010
Thread was dead, leave it be.
Register to reply
Related Discussions
In binary can we have a value with "deci" "centi" "mili" or more lower valued prefix? Computers 14
Difference between "Identical", "Equal", "Equivalent" Calculus & Beyond Homework 9
[SOLVED] "Assortment of Structural Steel Beams"&amp Engineering, Comp Sci, & Technology Homework 2
"An Account of the Fall Of a Meteoric Stone..." General Discussion 2
"The Engraved Stones of Ica in Ocacaje Peru and there story" Earth 0
