Register to reply
Pressure inside a balloon
by rubenhero
Tags: combined gas law, pressure
Share this thread:
rubenhero
#1
Dec3-11, 01:28 AM
P: 42
g) A spherical balloon of radius R = 1.95 m is made from a material of mass M = 4.56 kg and is filled with helium gas at temperature T = 289 K. Assume the thickness of the balloon is negligible compared to the radius of the balloon, and the balloon just floats on air, neither rising nor falling. If the density of the surrounding air is ρ = 1.13 kg/m3, find P, the absolute pressure of the helium inside the balloon.
ASSUME: The balloon material displaces a negligible amount of air, and therefore creates no measurable buoyancy.
2. Relevant equations
M g = ρ V g, PV = nRT, Volume of sphere = 4/3(∏r3), n = total mass/molar mass
3. The attempt at a solution
V = 4/3(∏r3)
V = 4/3(∏1.953)
V = 31.05935577m3
M g = ρ V g
MHe g = 1.13 kg/m3 * 31.05935577m3 * g
MHe = 35.09707202 Kg = 35097.07202g
n = total mass/molar mass = total mass He/molar mass He
n = 35097.07202g/ (4g/mol)
n = 8774.268005 mol
P= (nRT)/V
P = (8774.268005 mol * 8.314 J/mol-K * 289K) / 31.05935577m3
P = 678775.745 Pa
I thought all the steps I took were right, but the answer I calculated is wrong. Any help with figuring out what I did wrong is appreciated!
Phys.Org News Partner Science news on Phys.org
Fungus deadly to AIDS patients found to grow on trees
Canola genome sequence reveals evolutionary 'love triangle'
Scientists uncover clues to role of magnetism in iron-based superconductors
ehild
#2
Dec3-11, 01:37 AM
HW Helper
Thanks
P: 10,537
You ignored the mass of the balloon material, M(balloon)=4.56 kg.
ehild
rubenhero
#3
Dec3-11, 01:41 AM
P: 42
Wouldn't that mass be ignored if the balloon material displaces a negligible amount of air?
ehild
#4
Dec3-11, 02:09 AM
HW Helper
Thanks
P: 10,537
The volume of the ballon material is ignored, but not its mass. It is given as 4.56 kg. The buoyant force is equal to the total weight: the sum of the (mass of balloon material + the mass of helium) times g.
ehild
rubenhero
#5
Dec3-11, 02:24 AM
P: 42
Thank you for your help ehild, that "ASSUME: The balloon material displaces a negligible amount of air, and therefore creates no measurable buoyancy. " part really confused me. I accounted for the mass of the balloon material and got an answer to be 590585.5565Pa, I put in 5.90e5Pa and it is the right answer.
ehild
#6
Dec3-11, 02:40 AM
HW Helper
Thanks
P: 10,537
Splendid!
ehild
Register to reply
Related Discussions
Mars balloon , forces, pressure Introductory Physics Homework 11
The action of pressure on a balloon Introductory Physics Homework 0
Why does air way collapse when pressure outside exceeds pressure inside? General Physics 2
Finding the Initial Pressure of A Balloon Introductory Physics Homework 9
