New Reply
Urgent questions regarding plots results for computational theories for blunt bodies
Share Thread Thread Tools
Dec3-11, 03:15 AM   #1
I'm working on a hypersonics project in which I'm calculating the pressure and temperature using the Newtonian Method for a calorically perfect gas, Modified Newtonian Theory for a calorically perfect gas, Modified Newtonian Theory for a thermo-chemical equilibrium assumption.
I'm not sure if my pressure and temperature plots are correct for the TCE assumption. If I recall correctly, for the TCE assumption the pressure won't vary significantly but the temperature will. These pressure and temperature plots show this but I'm not about the order of magnitude. For the TCE assumption I'm using an iterative process that was outlined in class. I believe that this procedure is correct, because I calculate and plotted the pressure coefficient and the shape of all three curves are similar and the order of magnitude is not extreme. Could someone explain to me if the plots are correct? I'm a bit drained to think clearly and I've been going around in circles with this.
The pressure, temperature, and the pressure coefficient are plotted against the wetted distance of the blunt body scaled by the radius of the blunt body; s/Rb.
Pressure coefficient plot
http://www.mediafire.com/download.php?m712qqa9q2h2618
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Tags
calorically, cpg, gas, hypersonic, perfect
Thread Tools
Similar Threads for: Urgent questions regarding plots results for computational theories for blunt bodies
Thread Forum Replies
Radial Plots and Smooth Density Plots Math & Science Software 0
My logic vs. Calculated Results: Plots of Thrust, RPM, Spillage Aerospace Engineering 0
Some questions about Godel's Results Set Theory, Logic, Probability, Statistics 2
SUSY computational questions:dots! Quantum Physics 8
MATLAB : Step Plots [Urgent] Math & Science Software 0
