Spring oscillations determining period of motion
The discussion focuses on determining the period of motion and mass of a mass-spring system with a spring constant of k=18 N/m and an amplitude of 18 cm. The velocity at half the maximum position is given as v=27 cm/s. The period of motion can be calculated using the formula T=2π√(m/k), while the mass can be derived from kinetic energy principles, utilizing the work done by the spring during oscillation. The system is classified as undamped, allowing for the application of sine wave characteristics in calculations.
  • Understanding of Hooke's Law and spring constants
  • Familiarity with oscillatory motion and harmonic motion principles
  • Knowledge of kinetic energy and its relationship to mass and velocity
  • Ability to apply trigonometric functions in the context of wave motion
  • Learn about the derivation of the period of motion in mass-spring systems
  • Study the relationship between kinetic energy and potential energy in oscillatory systems
  • Explore the characteristics of undamped versus damped oscillations
  • Investigate the mathematical modeling of sine waves in physical systems
Students and professionals in physics, mechanical engineering, and anyone studying harmonic motion and oscillatory systems.
biga415
Hey guys, i can't figure this one out.
a mass attached to a spring oscillates with an amplitude of 18cm; the spring constant is k=18N/m. when the position is half the maximum value, the mass moves with velocity v=27cm/s.
a) determine the period of motion.
b)find the value of mass
i tried to find the mass first but that didnt work. i used kinematics, T= 2∏/ω, ω=sqrt(m/k) and T= 2∏sqrt(m/k) but none of them were working.
thanks for the help!
Is this a damped system or undamped?
If it is undamped, then the amplitude of oscillation is irrelevant, and the frequency is sqrt(k/m). Find m from the kinetic energy of the mass. You know how much the energy is because you know the work done by the spring during half of the amplitude.
P.S. You also know it will be a sine wave for an undamped system, and you know the amplitude of the wave and derivative at a point. You can calculate it that way too if you'd like.
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 131 ·
9K
