Solving Heat and Energy Problems for Monatomic Ideal Gas | Expert Tips
  • Thread starter Thread starter BlackMamba
    Gas Idea
This discussion focuses on solving heat and energy problems for a monatomic ideal gas, specifically addressing a scenario involving three moles of gas heated at constant volume. The key equations discussed include the first principle of thermodynamics for internal energy changes and the caloric state equation for temperature changes. The Mendeleev-Clapeyron formula is also highlighted for determining pressure changes. The user seeks clarity on these concepts to successfully solve the problem presented.
  • Understanding of the first principle of thermodynamics
  • Familiarity with the caloric state equation
  • Knowledge of the Mendeleev-Clapeyron equation
  • Basic concepts of monatomic ideal gas behavior
  • Study the first principle of thermodynamics for finite transformations
  • Learn how to apply the caloric state equation to calculate temperature changes
  • Research the Mendeleev-Clapeyron equation for pressure calculations
  • Practice solving problems involving monatomic ideal gases and constant volume scenarios
Students and professionals in physics and engineering, particularly those focusing on thermodynamics and gas laws, will benefit from this discussion.
BlackMamba
I am sick of these problems. I just cannot grasp these ideas at all and I'm really trying. But it's no use. And in the end, it's always something minor I'm overlooking.
I am having issues with the following problem: Three moles of a monatomic ideal gas are heated at a constant volume of 1.90 m^3. The amount of heat added is 5.48 x 10^3 J.
(a) What is the change in temperature of the gas?
(b) Find the change in it's internal energy.
(c) Determine the change in pressure.
So here's what I know:
n = 3
V = 1.90
Q = 5.48 x 10^3
So for (a) I believe I need to find (Ti - Tf) The equation I believed I needed to use was W = 3/2nR (Ti-Tf) But that leave me not knowing what W is?
For (b) I assumed I would use deltaU = 3/2nR DeltaT but this is just a pure guess.
And for (c) well I have no idea. If I had to guess I would have picked the equation W = P DeltaV but like I said it's just a pure guess.
I would really appreciate any direction given. It really frustrates me when I can't solve a problem by myself.
Thanks in advance
HINTS
1)Use the first principle of thermodunamics for finite transformations.That formula and the assumtion the volume is left constant (work is 0) should answer point b).
2)Use the calorical state equation to find the anwer to point a) which requires solving point b) as first,as i indicated.
3)Use Mendeleev-Clapeyron formula and a bit simple maths to find the expression for the pressure difference.
Good luck!
Thank you so much. That definitely helped me out.
