How Fast Must a Golf Ball Travel to Avoid Windmill Blades?
  • Thread starter Thread starter Crazedkid
    Angular
The problem involves determining the minimum speed a golf ball must travel to avoid being struck by rotating windmill blades. It is set within the context of rotational motion and angular speed.
  • Exploratory, Mathematical reasoning
  • Participants discuss calculating the width of the gap between the blades in relation to their angular speed. There is an emphasis on understanding the angular distance and the time required for the blades to cover this distance.
Some participants have offered guidance on how to approach the problem, including finding the angular distance and relating it to the time needed for the blade to pass. Multiple interpretations of the problem setup are being explored, particularly regarding the positioning of the golf ball relative to the blades.
The problem includes specific measurements such as the angular speed of the blades and the diameter of the golf ball, which are critical for calculations but may not be fully addressed in the discussion.
Crazedkid
ok i need help understanding were to start with this problem. any hint would be appreciated
A windmill has 8 blades abd rotates at an angular speed of 1.25 radians/second. The opening between succesive blades is equal to the width of a blade. A golf ball of diameter 4.50*10 -2m is just passing by one of the rotating blades. What is the minimum speed of the ball so that it will not be hit by the next blade?
I am soooo lost
Maybe start with how wide the gap between the blades is, expressed in radians...
Yup, first you have to find the angular distance of the opening. Since the question says that the opening is equal to the width of the blade, it implies that the [tex]\Theta=\frac{2\pi}{16}[/tex]. With the [tex]\Theta[/tex] and the angular speed, you can find out the time needed for the blade to cover this distance. For the golf ball to travel at minimum speed through the opening, you have to assume that the ball is right at the beginning of an opening before it passes through. Then it's easy to see that for the ball to pass through the opening, the distance that it needs to travel should be equal to at least its diameter. With the time you found and the known distance, you will find the answer.
thankyou very much for your help
