Solving Exponential Eqn: 4(2)^5x = sqrt(2)
  • Thread starter Thread starter aisha
    Exponential
This discussion revolves around solving an exponential equation of the form 4(2)^(5x) = √2. Participants explore the concept of expressing both sides of the equation with a common base, specifically focusing on the base of 2.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to find a common base for both sides of the equation and questions the validity of their approach after arriving at a potential solution. Other participants suggest different methods of manipulating the equation, such as rewriting both sides as powers of √2 and comparing exponents.
Participants are actively engaging with each other's reasoning, identifying mistakes in exponent manipulation, and providing guidance on how to proceed with the solution. There is a recognition of confusion and a collaborative effort to clarify the steps involved.
Some participants express uncertainty about the steps taken and the correctness of their solutions, indicating a need for further verification of their results against the original equation.
aisha
To solve this exponential equation (4)(2)^5x=square root of 2
I know the common base is 2 but how do i make the square root of 2 also a common base? Do i multiply both sides by ^2? When I did this I got x=1/40 I am not sure if this is the right way to do this question can someone tell me :confused:
[tex]4*(\sqrt{2} * \sqrt{2})^{5x} = \sqrt{2}[/tex]
I think you might be on the right track... could you explain what you did? I might have done it the way you were thinking but I got a different answer.
What I did
well first I found the common base of left side and got
(2^2) (2)^5x=square root of 2
then to get rid of the square root on the right I wasnt sure what to do but I decided to multiply both sides by ^2 and got [(2^2) (2)^5x]^2=2 so the exponents were [(2)(5x)]2 = 2 and then when i further simplified I got the exponent x to =1/40
When you got to here,
aisha said:
[(2)(5x)]2 = 2
, what did you do with the ^2 after the 2?
ms. confused said:
When you got to here,, what did you do with the ^2 after the 2?
I am not sure what u are talking about. :rolleyes:
Write both sides as powers of sqrt(2) and then compare powers.
lol sorry still confused can someone show me :rolleyes:
From here "[(2^2) (2)^5x]^2=2"
to here
"so the exponents were [(2)(5x)]2 = 2"
You ran into some difficulty. The first equation is [tex]\left[2^{2}2^{5x}\right]^2=2[/tex], which is fine. When you combined the terms inside the [] you multiplied the exponents when you should have added them. You should get [tex]\left[2^{2+5x}\right]^2=2[/tex]. Can you manage from here?
to here
Ok I see my mistake but not sure if my answer is right now i got x=-1/5
No, but I think I see where you're going wrong.
Does this help (I've made a small change) ? [tex]\left[2^{2+5x}\right]^2=2^1[/tex].
Hold on-remember the power of 2 outside the square brackets [].
It's always a good idea after solving one of these to test your solution back in the original equation.
:confused: ok this is what I am doing now the exponents are (2+5x)^2=1 this to 4+10x=1 then i get -3/10 =x
oh to check myself where do i sub in x? which part?
Your original equation was [tex]4*(2)^{5x} = \sqrt{2}[/tex]. If you replace the "x" in this equation with "-3/10", the equation should be true.
:smile: :smile: YAYAYA
IM SOO HAPPY LOL I finally got that THANKS SO MUCH everyone ESP SHMOE
  • · Replies 17 ·
  • · Replies 50 ·
