Power of a Fan and WindMill using Energy vs dynamic method)
The discussion focuses on calculating the power of a windmill using two distinct methods: the dynamics method and the energy method. The dynamics method derives power using the formula P = Fv, where force F is expressed as F = Aρv², leading to P = Apv³. Conversely, the energy method calculates power as Power = (1/2)ρAv³, based on kinetic energy considerations. Both methods yield the same result when the Bernoulli equation is integrated with momentum principles, confirming their validity and highlighting the relationship between force and energy in windmill power calculations.
  • Understanding of fluid dynamics principles, particularly the Bernoulli equation.
  • Familiarity with kinetic energy calculations in physics.
  • Knowledge of basic windmill mechanics and aerodynamics.
  • Proficiency in applying Newton's laws of motion to real-world scenarios.
  • Explore the Bernoulli equation and its applications in fluid dynamics.
  • Study the principles of kinetic energy and its relevance to wind energy conversion.
  • Investigate the relationship between pressure differentials and force in windmill blades.
  • Learn about advanced windmill design and optimization techniques for efficiency.
Engineers, physics students, and renewable energy researchers interested in wind energy systems and their efficiency calculations.
unscientific
Determine the power of a windmill using constants where appropriate.
P = Fv
K = (1/2)mv2
Dynamics Method
P = Fv
In time Δt, Δm amount of wind passes through the windmill, at speed of v.
Δp = vΔm
= v(AρΔx)
Dividing both sides by Δt,
F = Aρv2
P = Fv = Apv3Energy Method
In time Δt, Δm amount of wind passes through the windmill, with KE of (1/2)(Δm)v2 .
Energy Transferred = (1/2)(Δm)v2
= (1/2)(ρAΔx)v2
Power = (1/2)ρAv3 I've thought a long time about this; both methods make sense, but why are they different? Appreciate any help guys!
If you combine the Bernoulli equation with the momentum equation (force) across the blades by relating to pressure differential, you will see that you get the same result as you get with energy considerations.
so do is the dynamics method here wrong?
  • · Replies 67 ·
  • · Replies 21 ·
11K
