New Reply
Unique Factorisation Domains/Fields..
Share Thread Thread Tools
Dec5-11, 03:51 PM   #1
In my notes/online I have that for a set to be a field is a stronger condition than for a set to be a unique factorisation domain (obviously), but I'm confused about the concept of irreducibility in a field. For example in R\{0} there are no irreducible elements as far as I can tell? I'm trying to show whether a different ring is a UFD or not but again I find the concept of irreducibility difficult as here again the ring seems to have no irreducible elements.
Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec6-11, 01:12 AM   #2
Recognitions:
Homework Helper Homework Help
in any ring there are three classes of non zero elements: units, zero divisors, non unit non zero divisors. irreducibles are always, by definition, a subset of the non units. in a field, all non zero elements are units, hence there is no possibility of irreducibles.
Dec6-11, 04:16 AM   #3
Recognitions:
Quote by Zoe-b View Post
Thanks in advance.
perhaps you should tells us which ring you are trying to prove is a UFD.
Dec6-11, 01:41 PM   #4
Ok that makes sense, so is the statement that all fields are UFDs correct? Or just nonsense because the concept of factorisation only makes sense with regards to irreducibles?
Let 2^(1/n) be the real positive nth root of 2. If we consider Z [ 2^(1/n) ] as the image of Z[X] under the evaluation map f(X) -> f(2^(1/n)), then let R= union from n=1 to infinity of (Z [ 2^(1/n) ]). I have shown already that R is a subring of the reals but as far as I can see it has no irreducible elements-
If a is a member of Z[2^(1/p)] for some natural number p, say a = g(2^(1/p)) for some polynomial g in Z[X]. Then we can always take out a factor of 2^(1/2p) to give
a = 2^(1/2p) * h(2^(1/2p))
where h is some polynomial in Z[X] (with the same integer coefficients as g but different powers). So a is reducible.
Am I on the completely wrong track?
Dec6-11, 02:49 PM   #5
Recognitions:
Isn't the number 3 irreducible in this ring?
Dec6-11, 03:14 PM   #6
Ok I completely missed that the polynomial can have a constant term (being slow) so yes I think you're right, 3 is irreducible. But I still can't see whether or not it is a unique factorisation domain as any element where the polynomial has a zero constant term is reducible. For example there definitely is not a unique factorisation of the element 2 into irreducibles- infact there isn't any factorisation of 2 into irreducibles as far as I can see, nor (do I think!) is it a unit.
(I've just found a bit on wikipedia saying 'any field is trivially a UFD' which now makes sense to me but obviously my example is not a field).
Dec7-11, 12:11 PM   #7
Recognitions:
None of the fractional powers of 2 have inverses in this ring since negative powers are excluded. So two factorizations will be in-equivalent. How about two factorizations of the square root of 2?
New Reply
Thread Tools
Similar Threads for: Unique Factorisation Domains/Fields..
Thread Forum Replies
Unique acceleration in gravitational fields Special & General Relativity 2
Unique Factorization Domains Calculus & Beyond Homework 0
Integral Domains and Fields Calculus & Beyond Homework 0
A little factorisation Advanced Physics Homework 0
factorisation of x^22 -3x^11 +2 Linear & Abstract Algebra 2
