How do i differentiate something like 12/(x^+3)?2
  • Context: Undergrad
  • Thread starter Thread starter mutineer
    Differentiate
The discussion revolves around the differentiation of the function 12/(x^2+3). Participants explore methods for finding the derivative, particularly focusing on the chain rule and the concept of a "direct method" for differentiation.
  • One participant expresses confusion about differentiating 12/(x^2+3) and questions why their answer differs from the expected result, specifically regarding the multiplication by 2x.
  • Another participant asks if the original poster is familiar with the chain rule and prompts them to explain it.
  • A participant defines the chain rule as a method for differentiating composite functions but notes that the original poster prefers a "direct method" and questions if the chain rule is the only approach available.
  • Another participant suggests rewriting the function using negative exponents to clarify the differentiation process and explains that the chain rule requires multiplying by the derivative of the inner function, which they encourage the original poster to determine.
Participants do not reach a consensus on the preferred method for differentiation, with some advocating for the chain rule while others seek an alternative approach. The discussion remains unresolved regarding the effectiveness of the "direct method" versus the chain rule.
There is ambiguity regarding the definition of "direct method" as used by the original poster, and the discussion does not clarify the specific steps involved in applying the chain rule or any alternative methods.
mutineer
How do i differentiate something like 12/(x^+3)??2
I am acquainted with differentiating equations like (2x+5)^2 ( by chain rule and the direct method). But how do i go about with the equation 12/(x^2+3)? The specific doubt is that the answer given -12(x^2+3)^-2 into(multiplied by) 2x. I am getting the answer, but its not multiplied by 2x, so i get -12(x^2+3)^-2. I don't know why
Do you know about the chain rule ? What does it say ?
the chain rule is a formula for computing the derivative of the composition of two or more functions. But i don't want the chain rule method(if there is one in this case) for getting the answer, i want the direct method, or is chain rule the only way of doing it?
hi mutineer -
not sure what you mean by "direct method", but consider re-writing the expression as:
[itex]f(x) = \frac{12}{(x^2 + 3)} = 12\cdot (x^2 + 3)^{-1}[/itex]
If you define the denominator [itex](x^2 + 3) := g(x)[/itex], then f(x) becomes:
[itex]f(x) = 12\cdot \frac{1}{g(x)} = 12*\cdot g(x)^{-1}[/itex]
(I wrote this both as a fraction and using negative exponents to avoid confusion with the inverse f'n).
In your "direct method", you've computed the first part of the chain rule, i.e. you've found:
[itex]= \frac{d}{dx}f(x) = 12 \cdot \frac{d}{dx}g(x)^{-1} = 12 \cdot (-1)\cdot g(x)^{-2}[/itex]
But that /isn't/ the full derivative. Recall the chain rule requires you to multiply by the inside derivative as well. Here, the inside derivative would be g'(x) (the derivative of g(x) w.r.t. x; which I'll leave to you to sort out).
Hope this helps!
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 19 ·
