Strength/weight ratio question
  • Thread starter Thread starter faust9
    Ratio
The discussion revolves around the strength-to-weight ratio of die cast parts, particularly focusing on how this ratio changes with varying wall thickness. Participants are exploring the implications of wall thickness on material properties and structural performance.
  • Participants are examining the relationship between wall thickness and strength-to-weight ratio, with some suggesting that reducing wall thickness decreases weight without significantly affecting strength. Others are considering how factors like stiffness and structural geometry influence this relationship.
The conversation includes various perspectives on the topic, with some participants providing insights into related factors such as stiffness and material properties. There is an ongoing exploration of assumptions regarding how wall thickness affects overall performance, but no consensus has been reached.
Participants mention additional factors that may influence the strength-to-weight ratio, such as porosity, cooling rate, grain structure, and mold flow, particularly in the context of thin wall castings versus thicker ones.
faust9
Quick question: Why does the strenght to wieght ratio increase for die cast parts with decreasing wall thickness?
My view is that the weight decreases with nominal change in strength; however, a classmate of mine disagrees. Any thoughts?
I can see how the stiffness/weight ratio can be improved in an I-beam. If you make the web thinner (but not so thin that it buckles) you'll not change the second moment of area much, so you'll have almost the same stiffness, but you will save weight. Conversely, you might make the web thinner but deeper, keeping the same overall weight but increasing the second moment of area and so the stiffness.
Thanks. Additional delving into the topic showed us both that other factors such as porosity cooling rate grain structure and and mold flow are all 'typically' improved with thin wall castings versus thicker wall castings.
Thanks for the response.
For a component like a pipe, recall that the contribution to the stiffness from any volume element goes like the cube (I think) of the radial position from the axis. However, the contribution to the weight goes only as the square of the radial position. So removing material from smaller radial positions improves the strength-to-weight ratio.
That's why thin walled components are better for this.
  • · Replies 27 ·
  • · Replies 26 ·
