Who Can Crack the R-L-C Circuit Challenge?
  • Thread starter Thread starter Moore65
    Professors
The discussion focuses on solving an R-L-C series circuit problem driven by an AC source with an EMF of Vo=110.0V and frequency f=60.0 Hz. The circuit parameters include resistance R=20.0 Ohms, inductance L=5.0 * 10^-2 H, and capacitance C=50.0uF. Key calculations involve determining the impedance Z, phase angle α, and the potential drop across the inductor at time t=0 and the first maximum EMF. The potential across the inductor is expressed as U_L = (ωL) I_0 sin(ωt - α + π/2).
  • Understanding of R-L-C circuit theory
  • Knowledge of AC circuit analysis
  • Familiarity with impedance calculations
  • Proficiency in differential equations
  • Calculate the impedance Z of the R-L-C circuit using the formula Z = √(R² + (ωL - 1/(ωC))²)
  • Determine the phase angle α using α = arctan((ωL - 1/(ωC))/R)
  • Analyze the time-dependent current I(t) = I_0 sin(ωt - α)
  • Evaluate the potential drop across the inductor at t=0 and at the first maximum EMF using U_L = (ωL) I_0 sin(ωt - α + π/2)
Electrical engineering students, circuit designers, and anyone studying AC circuit behavior and analysis will benefit from this discussion.
Moore65
Can anyone solve this? I've asked 3 professors!
I'm having trouble trying to understand this problem.
The R-L-C series circuit is driven with a AC source with EMF=Vo*sin(wt) where Vo=110.0V and f=60.0 Hz. If R = 20.0 Ohms, L=5.0 * 10^-2 H, and C=50.0uF, find the potential drops across the inductor at to=0 and at a time t1=the first time after to that the EMF reaches a maximum.
The current moves through the circuit first through the resistor, then through the capacitor, and finally through the "L" before completely the cicuit.
I'm not really sure what to do, can anyone help?
The sum of the potential drops across the resistor, capacitor and inductor equals the applied voltage and can be expressed as a differential equation. Just solve it for the current and find the potential drop across the inductor as L dI/dt.
What have you learned about ac circuits? Do you know what "impedance" is?
The magnitude of the impedance of a series L-R-C circuit is
[tex]Z=\sqrt{R^2+(\omega L - 1/(\omega C))^2}[/tex]
and the phase of the impedance is
[tex]\alpha = \arctan ( \frac{\omega L - 1/(\omega C)}{R})[/tex]
The amplitude of the current through the circuit is
[tex]I_0 = U_0 /Z[/tex]
The phase of the impedance is equal to the phase difference between voltage and current: the current lags behind the voltage by this phase angle. The time dependence of the current is:
[tex]I(t) = I_0 \sin(\omega t - \alpha)[/tex]
The potential across the inductor leeds the current by pi/2. The impedance of the inductor is wL.
[tex]U_L = (\omega L) I_0 \sin (\omega t -\alpha + \ pi /2)[/tex]
First calculate Z, alpha, Io and then plug in t=0 to get the potential drop through the inductor at t=0. The emf reaches its maximum first when wt= pi/2, so just replace (wt) by pi/2 to get the potential drop at t1. .
ehild
  • · Replies 21 ·
  • · Replies 21 ·
