Is Y=23x+18 the Correct Equation for the Tangent Line at X=2?
The discussion revolves around finding the equation of the tangent line for the function F(X) = 2x + 7x(e^(x-2)) at the point x=2. Participants are examining the derivative and the resulting equation of the tangent line.
  • Participants discuss the process of finding the tangent line, including calculating the derivative and evaluating the function at x=2. There are questions about the correctness of the derivative and the resulting slope, as well as the equation of the tangent line.
Some participants have confirmed that the slope calculation is correct, while others are questioning the validity of the final equation y=23x+18. There is an ongoing exploration of how to determine the y-intercept and the relationship between the slope and the point through which the tangent line passes.
There are indications of confusion regarding the derivative and its application, with multiple posts reiterating similar points. Some participants express frustration over the clarity of previous explanations.
chjopl
Find the equation of the tangent line at x=2
F(X)=2x+7x(e^(x-2))
I know you put 2 into find the y intercept and you take the derivative to find the slope. I get 2+(7e^(-2)x + 7e^-2)e^2 for my derivative and y=23x+18 as my answer and i know that is not correct.
You derivative looks off. Remember,
[tex]\frac{d}{dx}e^{x-2}=e^{x-2}\frac{d}{dx}(x-2)=e^{x-2}(1)=e^{x-2}[/tex]
and apply the product rule carefully!
edit-ahh, Galileo is right, your slope is fine. Your posted derivative may be a casualty of ascii.
You got the slope right. So y=23x+b. Now use the fact that the line passes through the point (2,f(2)) to find b.
F(X)=2x+7x(e^(x-2))
The derivative should be:
[tex]f'(x)=2+[7\exp({-2})](\exp{x}+x\exp{x)[/tex]
Insert 2 to find the slope.It's 23.
Compute f(2).It's 18.With the last 2 numbers,u should be able to find the equation for the tangent line.
We're just like eagles when it comes to simple problems.Three almost identical posts at the same time...
so was y=23x+18 correct?
Obviously not,try to follow my post correctly.It's easy maths,after all.
What is 23(2)+ 18?
  • · Replies 18 ·
