| New Reply |
relativistic effects on planetary shear [tidal forces] |
Share Thread | Thread Tools |
| Dec7-11, 09:50 PM | #1 |
before i ask my question i want to review two points:
1. place a body like a moon or a planet near a black hole, as the body approaches the extreme gravity affects the body deferentially. 2. review the tidal forces on Jupiter's moon Io leading to volcanic/tectonic consequences. now take an identical copy of the earth and let it head through space with a velocity close the speed of light. even at these fantastic speeds nothing would be different on this new earth as compared to the original. however, the copy earth is still rotating so the side that is rotating into the direction of travel is getting even closer the speed of light. while the opposite side rotating away is going slower. even though this difference in velocities is only about 1 km/s can speeds sufficiently close to the speed of light yield a differential tidal force across the planet resulting affects on the geologic behavior of the planet [i.e. earthquacks, tectonics, etc...]? |
| Dec8-11, 06:24 AM | #2 |
You COULD include the moon. Nothing would change. Physics is (are?) the same in every inertial reference frame. It might look strange to an outsider, but that's just too bad. Our Earth would look that way to an observer moving by at relativistic speeds. |
| Dec10-11, 10:16 PM | #3 |
so lets pull our copy earth out of the black hole and place it back on its near speed of light velocity and since it is rotating then one side of the planet will be much more massive than the the other, would this not lead to tidal forces? [these are like the black hole tidal forces not moon-ocean tides]. plus the rotating will constantly change the parts the planet that are heavy and light. |
| Dec11-11, 02:00 AM | #4 |
There is no stress. Contrary to popular belief, moving at high velocities does not increase your mass. Objects moving near the speed of light do not collapse into black holes. It is only when you compare two different frames that you can even include things like kinetic energy into it. In such a case the energy would be found within the entire Earth, not just one side of it. Only then can you look at the different sides of the Earth and how it is rotating.
| New Reply |
| Thread Tools | |
Similar Threads for: relativistic effects on planetary shear [tidal forces]
| Radial tidal forces and tidal forces on moving objects redux | Special & General Relativity | 0 | ||
| Tidal Effects in the Schwarzschild Metric | Special & General Relativity | 12 | ||
| Equivalence Principle & Tidal Effects | Special & General Relativity | 26 | ||
| Tidal Effects of the Moon | Astrophysics | 5 | ||
| Tidal effects of WIMP-based dark matter on galaxies? | General Physics | 0 | ||
