forestmine
- 203
The small piston of a hydraulic lift has a diameter of 8.0 cm, and its large piston has a diameter of 40 cm. The lift raises a load of 15,000 N.
(a) Determine the force that must be applied to the small piston.
(b) Determine the pressure applied to the fluid in the lift.
p=F/A
I correctly solved for part a, and came up with an answer of 600 N. I'm a little unclear about how to obtain the answer for part b. My thought was that since pressure = F/A, I could simply take the pressure I found from part a, and divide by the area of the smaller piston, but I'm not getting the correct answer...
Thanks in advance!
