How can I get a seven segment display to light up in my circuit?
  • Thread starter Thread starter Tom McCurdy
    Light
The discussion revolves around troubleshooting a circuit involving a seven segment display, specifically focusing on the connections between the 7447 and LN514RK components. Participants explore various aspects of circuit design, including integrated circuits and display types.
  • One participant describes their frustration with a previous circuit and outlines their current setup, mentioning the use of a 555 timer and multiple integrated circuits.
  • Another participant suggests checking the connections of pins 3 and 4 of the 7447, indicating that they should be tied high based on the truth table.
  • A participant acknowledges not having tied those pins and mentions being advised to connect other pins of the display to positive.
  • Another contributor argues that current limiting resistors may not be necessary due to the internal current limiting of the 7447 and discusses the common anode configuration of the display.
  • There is a discussion about the need to connect pin 8 of the 7447 to ground and ensuring the correct logic levels for the lamp test and blanking input pins.
  • One participant expresses confusion about the connections between the 7447 and the LN514RK display, seeking clarification on which pins should be grounded or connected to positive.
  • A later reply confirms that the common cathodes of the display should be connected to ground.
  • Ultimately, a participant reports success after realizing the display was common cathode and switching to a 7448, which resolved their issue.
  • There is a request for recommendations on free software for circuit drawings.
Participants do not reach a consensus on the necessity of certain connections and components, with multiple views on the appropriate integrated circuit to use based on the display type. The discussion includes both agreement on troubleshooting steps and differing opinions on circuit design.
Participants reference specific pin configurations and truth tables, indicating that assumptions about the display type (common anode vs. common cathode) significantly impact the circuit design. The discussion does not resolve all uncertainties regarding the connections and configurations.
Individuals working on similar circuit designs involving seven segment displays and integrated circuits, as well as those interested in troubleshooting electronic components.
Tom McCurdy
Hello all, you may remeber from past about the circuit I was working on to get a simple 7 segment display to work... we had to tangent from that for awhile but we are finally back...
I got frustrated with problems in the 5 bread board circuit with around 100 led's so I streamlined the circuit with my partner and it now contains the integrated circuits on one board. I am trying to figure out how to get this stupid seven segment LED to light up
Here is a diagram of what I currently have built- The 555 works and blinks the two leds, also the 8 other leds work and count... however the seven segment display does not work.
www.quantumninja.com/hw/Circuit.pdf
I am not sure what to do with the final leads for the seven segment display
the parts used are
555-integrated circuit
7490-integrated circuit *2
7447-integrated circuit
LN514rk seven segment display
http://www.alldatasheet.com/datasheet-pdf/view/PANASONIC/LN514RK.html
specs for seven segment display
if link doesn't work just search www.alldatasheet.com for specific parts to get spec sheets
I don't know what to do to make it work please help!
Do you have pins 3 and 4 of the 7447 tied high? I don't see it on the schematic. Look at the truth table for the 7447.
Do you also have pins 3 and 14 of the display tied to gnd?
Um no I don't ...I was just told to tie the other pins of the display to positive... hmm
jrz126 said:
First off, I don't think you need those current limiting resistors between the 7 seg and 7447, It has internal current limiting.
For the 3 remaining pins, I'm assuming that your 7 seg display has 10 leads total: 7 for the display (a,b,c,d,e,f,g) then you have 2 commons, (are they common annode?) and the final lead is for the decimal.
Usually the 2 commons are in the middle of the top and bottom.
It looks like the 7447 should be able to support common annodes. Just connect the 2 commons to your +5 volts.
looking at your drawing, You also need to connect pin 8 of the 7447 to ground.
Looking at the truth table for the 7447, you want pin 3 (Lamp test) high, if you bring this low, it should light every segment of your display, a good way to check it. You also want your blanking input (pin 4) high. and I think you will want pin 5 high as well.
Hope this isn't confusing, Feel free to send me an IM if you have any questions.
One thing I was also considering was making sure that the LN514rk 7 segmetn display is common anode as opposed to common cathode... becasue if its common cathode wouldn't I need the 7448 instead of the 7447?
What I really need to know is the connections between the 7447 and ln514rk ... what goes ground what goes positive
Your common cathodes (pins 3 & 14) should go to gnd.
HAHAHAHAHA I got it!
I realized that the led was common cathode and so switched the 7447 with a 7448 and it worked
thanks a lot for the help though guys... does anyone know of any free software taht streamlines circuits drawings?
