What Was the Initial Velocity and Direction of Object m1 Before Collision?
  • Thread starter Thread starter Jameson
The initial velocity of object m1, with a mass of 2.68 kg, before the collision was calculated to be 31.3 m/s at a compass heading of 19.6 degrees. This was determined using the conservation of momentum principle, which equates the total momentum before and after the collision. The final velocities of both objects were provided: m1 moves at 11.8 m/s at 329 degrees and m2 at 11.6 m/s at 212 degrees, while m2's initial velocity was 9.3 m/s at 306 degrees.
  • Understanding of conservation of momentum in physics
  • Ability to resolve vectors into x and y components
  • Familiarity with trigonometric functions, specifically tangent
  • Basic knowledge of compass headings and angles
  • Study the principles of conservation of momentum in two-dimensional collisions
  • Learn how to resolve vectors into their components using trigonometry
  • Explore the application of the tangent function in calculating angles from vector components
  • Investigate real-world examples of momentum conservation in collisions
Physics students, educators, and anyone interested in understanding collision dynamics and momentum conservation principles.
Jameson
Insights Author
MHB
Two objects collide and bounce off one another. After the collision, object m1 = 2.68 kg moves off at 11.8 m/s at a heading of 329 degrees. Object m2 = 2.88 kg moves off at 11.6 m/s at a heading of 212 degrees. Initially, m2 was traveling at 9.3 m/s at a heading of 306 degrees. What must have been the initial velocity of m1? Give the speed for your first answer and the compass heading for your second answer. (remember, the CAPA abbreviation for degrees is deg)
someone help me. I'm lost. :cry:
Use conservation of momentum. Treat x (East) and y (North) components separately.
Sure, I can help you solve this problem. First, we need to use the conservation of momentum principle, which states that the total momentum before a collision is equal to the total momentum after the collision.
We can set up two equations to represent the momentum of each object before and after the collision:
m1v1 + m2v2 = m1v1' + m2v2' (equation 1)
Since we are looking for the initial velocity of m1, we can solve for v1:
v1 = (m1v1' + m2v2' - m2v2) / m1 (equation 2)
Now, let's plug in the given values into equation 1:
(2.68 kg)(v1) + (2.88 kg)(9.3 m/s) = (2.68 kg)(11.8 m/s) + (2.88 kg)(11.6 m/s)
We can simplify this to:
(2.68 kg)(v1) = (2.68 kg)(11.8 m/s) + (2.88 kg)(11.6 m/s) - (2.88 kg)(9.3 m/s)
v1 = (2.68 kg)(11.8 m/s) + (2.88 kg)(11.6 m/s) - (2.88 kg)(9.3 m/s) / (2.68 kg)
v1 = 31.3 m/s
So, the initial velocity of m1 was 31.3 m/s. Now, let's find the compass heading. We can use trigonometry to solve for the angle:
tan θ = (v1y) / (v1x)
θ = tan^-1 ((v1y) / (v1x))
θ = tan^-1 (11.8 m/s / 31.3 m/s)
θ = 19.6 deg
Therefore, the initial velocity of m1 was 31.3 m/s at a heading of 19.6 degrees. I hope this helps!
