Work (Physics)
by Drey0287
Tags: physics, work
Drey0287
Drey0287 is offline
#1
Dec7-04, 07:18 PM
P: 7
A 50-kg crate is pulled 40 m along a horizontal floor by a constant 100 N force exerted by a person which acts at a 37 degree angle above the horizontal. Determine the work done on the crate.
I know the equation for work is
work = F * delta X (triangleX) OR work = m*acceleration*deltaX
But where do I use the 37 degree angle?????
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
ascky
ascky is offline
#2
Dec7-04, 07:24 PM
P: 51
You have to take into account the direction of the force
W=Fxcos(theta)
dextercioby
dextercioby is offline
#3
Dec7-04, 07:28 PM
Sci Advisor
HW Helper
P: 11,863
Quote Quote by Drey0287
If the force would have acted parallel to the horizontal,u could have stated that the work is simply the product between the force's magnitude (100 N) and the distance (40m).That would not be the case,though,because not all of that force is acting on the crate.Only the horizontal component does.Then u should check whether the vertical component annulates the pression force on the ground as to lift the crate.Simple manipulation of numbers shows you that it doesn't.
Hopefully u're clear now.
Raza
Raza is offline
#4
Dec7-04, 08:20 PM
P: 208
Work (Physics)
Question:
Solution:
Work=(Force)(Displacment)(COS degrees)
[tex]W=fdcos[/tex]
[tex]=(100)(40)(Cos 37)[/tex]
[tex]=(100)(40)(0.80)[/tex]
[tex]=3200 J[/tex]
[tex]=3.2 kJ[/tex]
I might be wrong.
Register to reply
Related Discussions
Physics BSc student looking for physics related work over the summer Academic Guidance 2
how does physics work? General Discussion 18
Physics: work Introductory Physics Homework 6
