Calculating rotational inertia of a sphere
The discussion revolves around calculating the rotational inertia of a sphere, specifically focusing on the methods and approaches to derive the moment of inertia using integration techniques.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to calculate the rotational inertia by dividing the sphere into cross-sections and integrating, but expresses uncertainty about the integration limits and whether to use spherical coordinates. Other participants provide alternative methods involving thin disks and suggest integrating over specific dimensions.
Participants are exploring different methods to approach the problem, with some offering guidance on using thin disks and integration techniques. There is a mix of interpretations regarding the setup of the problem, and while some participants express understanding, no consensus has been reached on the best method to use.
The original poster indicates confusion about the integration process and whether to include certain variables, highlighting potential gaps in their understanding of the topic. There is also mention of a textbook not providing adequate help, which may affect the discussion's direction.
Silimay
Just how do you calculate the rotational inertia of a sphere?
Assuming the sphere lies at the center of the xyz coordinate system, I divided the sphere into a series of cross-sections of verticle width dz and area pi*y^2. I then multiplied these together and multiplied this by z^2, and multiplied this by density (M/V, or M/(4/3*pi*R^3)), and then tried to integrate with respect to z from -R to R. I wasn't sure whether or not to include z itself in the integration (z=(R^2-Y^2)^(1/2)). I have a feeling I completely messed the entire problem up; however, I'm not sure where. Did I go about doing it in an entirely wrong way? Should I use double integrals (would that be easier)? Do I have to use spherical coordinates or something?
Any help is appreciated. :smile:
Your answer lies here
Hopefully Arildno and Krabs' approach are within your level of understanding...
Thank you thank you thank you! That was REALLY helpful...I've been trying to understand the process of calculating inertia for days...my textbook was of no help. I think I finally understand it.
Divide the solid sphere into thin disks of thickness dz and mass dm. For the thin disk is [itex]I = \frac{1}{2}MR^2[/itex]
The moment of inertia of each disk is
[tex]dI = \frac{1}{2}x^2dm[/tex] where [tex]dm = \rho \pi x^2 dz[/tex]
So [tex]dI = \frac{1}{2}\rho \pi x^4 dz[/tex]
Then integrate dI from z = -R to R (note: [itex]x^2 = R^2 - z^2[/itex])
That will give you I in terms of [itex]\rho[/itex] which is M/V (where V is the volume of the sphere and M is its mass) so just replace [itex]\rho[/itex] with M/V.
The integration looks a little tough because of the [itex](R^2 - z^2)^2[/itex] Good luck.
AM
  • · Replies 17 ·
  • · Replies 28 ·
