| Thread Closed |
Why is the speed of light 299,792,458 metres per second? |
Share Thread | Thread Tools |
| Dec8-04, 07:07 AM | #1 |
Can anybody explain it to me?
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Dec8-04, 07:55 AM | #2 |
What exactly is your question? The only answer to the question as you have phrased it is "because that's the way the metre is defined"! If you used some other unit for length, you would get another number. In texts on relativity it is common to assume 1 "light-second" as the unit of length so that the speed of light is 1.
If your question is really "why is the speed of light the same in all frames of reference" I doubt that any one can give you a simple answer. |
| Dec8-04, 08:07 AM | #3 |
nope, not that. OK, why does the speed of light appear to be the speed it is when measured? What initial condition caused it to be the speed we observe it at, and not 10m/s for instance? |
| Dec8-04, 08:16 AM | #4 |
Why is the speed of light 299,792,458 metres per second?Daniel. |
| Dec8-04, 08:26 AM | #5 |
Each theory came up with it's own version of cosmology.SM came with the BB.GR came with the BB.Yet the theory which apparently incorporates best GR and QFT/SM,the string/superstring/M theory comes up with a staggering version on cosmology,saying there was no "big bang" and that the universe had 11 dimensions and be filled with interacting 10 dim.superstrings floating in the 11-th dimention. For the SM version of BB,see Steven Weinberg's book"The first 3 minutes". For why was there a BB (the GR version) see the book by Hawking and Ellis:"The large scale structure od space-time". Daniel. |
| Dec8-04, 11:37 PM | #6 |
Recognitions:
| Dec9-04, 02:27 AM | #7 |
Units of measure aside, the speed of light is determined by the permeability and permittivity constants, which are in turn measures of the electric and magnetic properties of space.
| Dec9-04, 05:11 AM | #8 |
| Dec9-04, 01:26 PM | #9 |
Recognitions:
Back in the days when the meter was a pair of lines on a bar kept in a box in Paris, the speed of light was a number that was measured. When it became clear that our distance standard (the physical bar) was limiting the precision with which we could measure the speed of light, we changed the standards to something more precise and repeatable than the use of this physical artifact. The first change was to specify a certain number of wavelengths of a particular transition frequency, but this defintion was found wanting. So eventually the meter was defined in terms of the speed of light, because that allowed for the most precise and repeatable definition of the meter.
The reason the numerical values that exist were chosen were for compatibility with the "old" meter. The intent was that the "new" meter and the "old" meter would be the same for all practical purposes, just that the new meter would be more precise than the old meter ever could be. So historical compatibility with a pair of marks on a bar was the reason that the speed of light has the numerical value it does today. The length between the marks on the bar originally had it's own motivation at the time it was created, but I don't recall all the details, I believe it was supposed to be some fraction of the Earth's circumference. |
| Dec9-04, 03:02 PM | #10 |
I think the question is more about fundamental relationships rather than our arbitrary choice of units, but the point is completely valid that the actual value is an artificial construct.
First we got the permittivity constant from Coulomb's Law, then the permeability constant from the Biot-Savart law, and Maxwell combined these to predict the known measured value of the speed of light as the speed of a traveling electromagnetic wave. This suggested the EM nature of light. Quoting Maxwell These two constants - permeability and permittivity - are determined experimentally and they were long considered to be fundamental. I assume that String Theory can or will [if the theory is correct] predict these constants by using yet more fundamental values, but I don't know if must be true. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why is the speed of light 299,792,458 metres per second?
| Can photons be accelated or do they always travel at one speed (speed of light)? | General Physics | 25 | ||
| Real time effects of light, light speed, and the sun? | General Astronomy | 4 | ||
| Speed of light Schmeed of light: things can travel faster | Special & General Relativity | 13 | ||
| Does the Speed of Light Change depending on different Light Frequencies? | General Physics | 15 | ||
| revs per min from metres per second | Introductory Physics Homework | 7 | ||
