pmb
Since I defend the concept of mass when it comes up I thought it might be of interest to others to note something very interesting. In Einstein's paper "On the Electrodynamics of Moving Bodies," of 1905 (http://www.fourmilab.ch/etexts/einstein/specrel/www/) he made an error on the value of transverse mass (in 1906 Planck published a paper showing that one can write Force as F = dp/dt where p = mv and m = relativistic mass = m_o/sqrt[1-(v/c)^2]). This has already been noted in the physics literature. Most notably in two papers -In his book "Albert Einstein's Special Theory of Relativity," Arthur Miller, pp. 328-331, the author explains the transverse mass error. This error was also noted in the now well known paper "Does mass really depend on velocity, dad?" Carl G. Adler, Am. J. Phys., 55(8), Aug 1987 page 742
It should be noted that Einstein's original formula for transverse
mass was incorrect. It was corrected by Planck in 1906. Planck was the
first to introduce the formula m_o*v/sqrt[1-(v/c)^2].
But it seems there is some misinformation being passed around the web on this subject (notably by someone who was banned from here but is still posting misinformation elsewhere). Clarity is in order.
In the 1905 paper Einstein examines the motion of a charged particle which is instantaneously at rest in the primed system in which there is a pure electric field. At t' = 0 the charge is at the origin of the primed system S'. In the unprimed frame S the particle is moving in the +x direction and at t = 0 the charge is at the origin of S. Einstein writes for S'
Einstein uses (X,Y,Z) for (E_x, E_y, E_z) and (L,M,N) for (B_x, B_y, B_z). I use the regular E_x, etc. m = rest mass
First Einstein considers the particle to be at rest in S
m*d^2x/dt^2 = qE_x
m*d^2y/dt^2 = qE_y
m*d^2z/dt^2 = qE_z
That's the first equation. It holds since m*d^x/dt^2 is the force since the particle is instantaneously at rest and therefore gamma = 1. Then he addresses the moving partricle which is at rest in S' and therefore (I use x', y', z' while einstein uses Greek letters). Remember in S' there is only an electric field
m*d^2x'/dt^2 = qE'_x
m*d^2y'/dt^2 = qE'_y
m*d^2z'/dt^2 = qE'_z
Now Einstein transforms to S
d^2x/dt^2 = (q/m*gamma^3)E_x
d^2y/dt^2 = (q/m*gamma)(E_y - vB_z)
d^2z/dt^2 = (q/m*gamma)(E_z + vB_y)
rewritten
gamma*md^2x/dt^2 = qE_x = x-component of Lorentz Force
gamma*m*d^2y/dt^2 =q(E_y - vB_z) = y- component of Lorentz Force
gamma*m*d^2z/dt^2 = q(E_z + vB_y) = z- component of Lorentz Force
These are the correct equations of motion.
Einstein makes the error of equating m*gamma^2 d^2/dt^2 = q*gamma(E_y - vB_z) with qE'_y and thus he gets the wrong value for the transverse mass (same with the other components). In effect what he does is fail to transform the force. He writes an expression like
MA = F' and then calls M transverse mass. This of course is incorrect since to call the M 'mass' one has to have all components in the same system. So if F = MA then one can call M a 'mass.'
For details see -
http://www.geocities.com/physics_world/sr/ae_1905_error.htm
Pete
m*d^2x/dt^2 = qE_x
m*d^2y/dt^2 = qE_y
m*d^2z/dt^2 = qE_z
rewritten
For details see -
Pete
