A Little Problem with a Simple Integral
  • Context: Graduate
  • Thread starter Thread starter Alamino
    Integral
The discussion revolves around the evaluation of a specific integral involving the Gaussian function and the step function, exploring the implications of using complex analysis techniques, particularly residue calculus, in this context. Participants are examining the correctness of the steps taken in the integral evaluation and the assumptions made regarding the behavior of the integrals involved.
  • One participant presents an integral involving the Gaussian function and the step function, asserting that the integral evaluates to 1/2.
  • Another participant questions the transition between expressions and suggests that the last integral cannot be closed due to the nature of the complex variable k.
  • A third participant proposes a different interpretation of the integrated function, suggesting it can be treated as a Gaussian function in terms of |k|^2.
  • A fourth participant challenges this interpretation, stating that |k|^2 does not equal k^2 for complex numbers, highlighting the distinction between real and complex values.
Participants express differing views on the validity of the integral evaluations and the assumptions made regarding complex variables. No consensus is reached, and multiple competing interpretations are presented.
Participants have not fully resolved the implications of using residue calculus in this context, particularly regarding the behavior of the integrals over complex contours and the assumptions about the convergence of the integrals involved.
Alamino
If we have
[tex]P(x)=\frac{1}{\sqrt{2\pi}}e^{-\frac{1}{2} x^2},[/tex]
then
[tex]I=\int^{+\infty}_{-\infty}dx \, P(x) \theta(x)<br /> = \int^{+\infty}_0 dx \, P(x)=\frac{1}{2},[/tex]
where [tex]\theta[/tex] is the step function. Now, using its integral representation, we have
[tex] I=\int^{+\infty}_{-\infty}dx \, P(x) \frac{1}{2\pi i} \int^{+\infty}_{-\infty} \frac{dk}{k} \, e^{ikx} = \frac{1}{2\pi i} \int^{+\infty}_{-\infty} \frac{dk}{k} \int^{+\infty}_{-\infty}dx \frac{1}{\sqrt{2\pi}} e^{-\frac{1}{2}x^2+ikx}= \frac{1}{2\pi i}\int^{+\infty}_{-\infty} \frac{dk}{k} e^{-\frac{1}{2} k^2} .[/tex]
But the integral over [tex]k[/tex] is calculated using residues and gives [tex]2\pi i[/tex] times the residue at [tex]k=0[/tex], what gives simply [tex]2\pi i[/tex] for the integral over [tex]k[/tex] and the wrong result 1 for the integral [tex]I[/tex]. I cannot see the catching. What is wrong with this calculation?
Could you explain how you got from the second to last to the last expression? Also, I don't think you can close that last integral, because k is squared. So it will only go to 0 as R goes to infinity if -(x^2-y^2)<0, or |x|>|y|, where k=x+iy, and this is not true over the entire contour.
The passage you're referring to is a gaussian integration. I'm not so sure (maybe all the problem is here), but I think that I can consider the integrated function as [tex]e^{-|k|^2/2}[\tex], what gives k squared for the reals and has not the problem you mentioned.[/tex]
I don't think you can do that. |k|^2 does not equal k^2 for complex numbers. In particular, the first is real while the second isn't.
  • · Replies 27 ·
  • · Replies 19 ·
