New Reply
finding work, heat, and entropy in a heat engine
Share Thread Thread Tools
Dec14-11, 10:12 AM   #1
An engine operates with n = 1.94 moles of a monatomic ideal gas as its working substance, starting at volume VA = 21.4 L and pressure PA = 2.77 atm. The cycle consists of:
- A to B: an isobaric expansion until its volume is VB = 50.1 L
- B to C: an isochoric (constant volume) process that lowers the pressure to PC = 1.184 atm
- C to A: an isothermal (constant temperature) process that returns the gas to its original pressure and volume
HINT: Draw a P-V diagram of this process.
a) Find TT, the absolute temperature of the isothermal process.
b) Find WT, the work done on the gas during the isothermal process.
c) Find ΔST, the change in entropy of the gas during the isothermal process.
d) Find Wtot, the work done in the entire cycle.
e) Find Qtot, the heat that is exchanged (in or out) during the entire cycle.
2. Relevant equations
PV=nRT, Wdone on a gas = nRTln(Vo/Vf),
ΔS = Qrev/T, Qp = CpT, Cp = 5/2nR,
Qv = CvΔT, Cv = 3/2nR
3. The attempt at a solution
necessary conversions:
1 atm = 1.013e5 Pa
2.77 atm = 280601 Pa
1.184 atm = 119939.2 Pa
1L = 1/1000 m^3
21.4 L = .0214 m^3
50.1 L = .051 m^3
2 a) Find TT, the absolute temperature of the isothermal process.
PV = nRT
PV/nR = T
(280601Pa * .0214m^3)/ (1.94 moles * 8.314 J/mol-K) = T
372.2984582K = T
372 K = T [webassign marked as correct] 3 significant digits
Won the gas = nRT ln(Vo/Vf)
= 1.94 moles * 8.314 J/mol-K * 372 K ln(.051m^3/.0214m^3)
= 5214.830072 J
Won the gas = 5.21e3 J [webassign marked as correct] 3 significant digits
change in IE is 0 since it is an isothermal process, work is positive because the gas was compressed and work was done on the gas
change IE = Q + W
0 = Q + 5214.830072 J
-5214.830072 J = Q
dS = dQrev/T
= -5214.830072 J/ 372.2984582 K
= -14.0071224 J/K
dS = -14.0 J/K [webassign marked as wrong] 3 significant digits
plan : find work done in all parts of the cycle and get sum
A-B is an isobaric process so W = -PdV
= -280601 Pa * (.051m^3 - .0214m^3)
= -8365.7896 J
B-C is an isochoric process so W = 0
C-A is an isothermal process (taken from part 2b) W = 5214.830072 J
Wtot = WA-B + WB-C + WC-A = -8365.7896 J + 0J + 5214.830072 J
Wtot = -3090.959528 J
Wtot = -3.09e3 J [ webassign marked as wrong] 3 significant digits
plan : find heat in all parts of the cycle and get sum
A-B is an isobaric process so Q = CpdT
= 5/2 n R dT
we need the different temperature at points A and B to get dT:
@ A : PV/nR = T
= (280601Pa * .0214m^3)/ (1.94 moles * 8.314 J/mol-K) = T
= 372 K
@B : PV/nR = T
= (280601Pa * .051m^3)/ (1.94 moles * 8.314 J/mol-K) = T
= 887.253335 K
dT = TB - TA = 887.253335 K - 372.2984582 K = 515 K
so now QA-B = 5/2 n R dT
= 5/2 * 1.94 moles * 8.314 J/mol-K * 515 K
= 20764.474 J positive because heat was added to the system
B-C is an isochoric process so Qv = CvdT
= 3/2 n R dT
we need the different temperature at points B and C to get dT:
@B : PV/nR = T
= 887.253335 K
@C : PV/nR = T
= (119939.2Pa * .051m^3) / (1.94 moles * 8.314 J/mol-K) = T
= 379.2447468 K
dT = TB - Tc = 887.253335 K - 379.2447468 K
= 508.0085882 K
= 508 K
so Q = 3/2 n R dT
= 3/2 1.94 moles * 8.314 J/mol-K * 508 K
= -12290.6277 J negative because heat was removed
C-A is an isothermal process and we already figured out Q is -5214.830072 J from part 2b
so finally Qtot = QA-B + QB-C + QC-A
= 20764.474 J + -12290.6277 J + -5214.830072 J
= 3259.016228 J
= 3.25e3 J [webassign marked as wrong] 3 significant figures
thank you in advance for any input as to why my work might be wrong.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec14-11, 10:57 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Quote by rubenhero View Post
1L = 1/1000 m^3
21.4 L = .0214 m^3
50.1 L = .051 m^3
VB=0.0501 m^3.
Recalculate the isotherm work with the correct volume. Also try to use more significant digits in T.
ehild
Dec14-11, 11:23 AM   #3
Thank you ehild, I redid all the work and got the correct answers.
New Reply
Tags
thermodymanics
Thread Tools
Similar Threads for: finding work, heat, and entropy in a heat engine
Thread Forum Replies
Finding work done, heat in, and heat out over a reversible thermodynamic cycle Introductory Physics Homework 3
Heat Engine and Entropy Change Introductory Physics Homework 5
heat engine, maximum work Introductory Physics Homework 6
Finding exhaust temp in heat engine problem (entropy) Introductory Physics Homework 1
work of a heat engine Introductory Physics Homework 3
