Rational Expressions loooong BUT NEED HELP
The discussion centers on the analysis of the function f(x) = (1)/(4x^2) - 1, specifically identifying its vertical asymptotes, x-intercepts, y-intercept, domain, and range. The x-intercepts are confirmed as x = -1/2 and x = 1/2, while the y-intercept is y = -1. The vertical asymptotes are also correctly identified at x = -1/2 and x = 1/2. The domain is expressed as ℝ \ {-1/2, 1/2}, and the range is ℝ \ {0}, indicating that the function does not equal zero.
  • Understanding of rational functions and their properties
  • Knowledge of vertical asymptotes and intercepts
  • Familiarity with function notation and set notation
  • Basic graphing skills for visualizing functions
  • Study the properties of rational functions and their asymptotic behavior
  • Learn about the concept of local maxima and minima in calculus
  • Explore the use of set notation in mathematical expressions
  • Practice graphing rational functions to visualize their behavior
Students studying algebra, calculus enthusiasts, and anyone interested in understanding the behavior of rational functions and their graphical representations.
aisha
state the vertical asymptote(s), x-intercept(s), y-intercept(s), domain and range of f(x)=(1)/(4x^2)-1
ok I factored the denominator and got (2x+1) (2x-1) I solved for x, so the x-intercepts are x=-1/2, and x=1/2 for only (4x^2)-1 the reciprocal function has no x-intercepts.
Sub in x=0 to get y intercept, I got y=-1 for (4x^2)-1
that means for f(x)=(1)/(4x^2)-1 it must be the same since -1 is an invariant point.
Ok I think the vertex is (0,-1) for (4x^2)-1 this is also the vertex of f(x)=(1)/(4x^2)-1 but this function has a maximum instead of minimum.
I gather the vertical asymptotes are x=-0.5, and x=0.5 for f(x)=(1)/(4x^2)-1
The Range for f(x)=(1)/(4x^2)-1 {y:y does not equal 0 but is YER} if this is correct what is the proper notation.
The Domain for f(x)=(1)/(4x^2)-1 {x:does not equal -1/2 or 1/2, but is XER}
if this is correct what is the proper notation?
Ok um I don't know if all that I have said is correct, can someone please Help me out?
I have a sketch of the graph but the forum won't let me attach it it is saying it is too big...
it sort of looks like JUL
n
a parabola with a min is the original and then the reciprocal is a parabola with a max and in the top two quadrants a backwards L and L .
I DONT KNOW IF THIS MAKES ANY SENSE, but I TRIED. :redface:
Hi Aisha,
Is the function
[tex]f(x)=\frac{1}{4x^2}-1[/tex] or [tex]f(x)=\frac{1}{4x^2-1}[/tex]?
Your notation implied the former one, but then you cannot factor the denominator like [itex](2x-1)(2x+1)[/itex]. You can do so only in the latter one. I take it that's the one you meant.
The notation you want for the range is :[tex]\mathbb{R}\setminus \{0\}[/tex], which means [itex]\mathbb{R}[/itex] minus the set [itex]\{0\}[/itex]. So minus the point 0.
It's not correct though.
The function looks more like [itex]J_\cap L[/tex] then JUL <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" /> <br /> Anyway, look for the extrema, you`ll find there's a local maximum at x=0.<br /> (0,-1), I guess you already found it. Never heard it being called a vertex though. That means the function is smaller than -1 in the interval (-1/2,1/2) and larger than 0 elsewhere in its domain.<br /> <br /> The domain is correct, a correct notation would be [itex]\mathbb{R}\setminus \{-\frac{1}{2},\frac{1}{2}\}[/itex]<br /> <br /> The asymptotes are ok too.[/itex]
Yes It Is The Second One! I Still Need More Help Please! Anyone!
  • · Replies 21 ·
