Reciprocal Function Graph: How to Determine the Equation?
  • Thread starter Thread starter aisha
    Graph
The discussion revolves around determining the equation of a reciprocal function based on its graph, which features asymptotes at x=1 and x=-1. Participants describe the shape of the graph and its characteristics, including invariant points and a parabola situated between the asymptotes.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants explore different forms of the function f(x) and attempt to derive it from the graph's features. There are discussions about using specific points from the graph to find coefficients in a proposed function form. Questions arise regarding the correctness of the derived equations and the methods used to find them.
Some participants express uncertainty about their approaches and the accuracy of their equations. There is an ongoing exploration of different function forms and attempts to validate them against the graph. No consensus has been reached, and multiple interpretations of the function's characteristics are being considered.
Participants mention the use of graphing calculators to verify their equations, indicating a reliance on visual confirmation of their work. There is a sense of urgency and frustration expressed by some participants regarding their progress in solving the problem.
aisha
OK I am given the graph of a reciprocal function the asymptotes are x=1 and x=-1
Quadrants ____1____|____2_____
3 | 4
Ok in the first quadrant there is a > looking curve going through the invariant point 1 and in the second quadrant there is a < curve going through the invariant point 1. then there is a parabola with a max of -1 inbetween the asymptotes.
The question says determine the equation of the graph, so I need to find f(x) and then to get the reciprocal just put 1/(f(X)). I sketched f(x) but how do I find out the eqn? :confused:
Does it look like the [tex]f(x)=\frac{1}{4*x^2-1}[/tex] in your other thread?
If so, try a function with a similar form: [tex]f(x)=\frac{a}{bx^2-c}[/tex]
and find a,b and c by plugging in coordinates from the graph.
no i graphed the equation in my other post it does not look similar to this one. I still have no idea of how to determine the equation, all I know is to find the equation of f(x) first then find 1/f(x). :cry:
Well this is what I just tried since the vertex of f(x) is 0,-1 I subbed this into the equations y=a(x+h)^2-K and then I took a point from the graph (the invariant point, 1,1) and then solved for a... a=2 so my equation for f(x) became 2x^(2)-1 that means the reciprocal must be 1/2x^(2)-1
Im not sure if this is the correct way, I tried graphing the equation using my ti 83 graphing calculator, but the reciprocal function looks different from the one on my hand out, so i can't check If I am right? What do I do? does this seem right? :cry: please HELP ME !
Please Help Me Please
:cry: No one is helping me out, I am stuck well I tried and for my graph I got the equation 1/(2x^(2)-1) . HELP PLEASE
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 25 ·
