Heat transfer through wall - Insulation thickness
by klopjob
Tags: heat, insulation, thickness, transfer, wall
klopjob
klopjob is offline
#1
Dec16-11, 05:24 AM
P: 2
Alright, chemistry student here. No previous experience with these types of problems. Doing an interdisciplinary student project where we have to insulate a thin aluminum wall.
http://i.imgur.com/8ztNq.gif
We have a x=5mm thin aluminium wall used for dividing two air flows. T1=308 K and T2=283 K. Aluminium has a thermal conductivity of k=220 W/m,K. Assuming the wall areas are 1 m2 we can use the equation
1/U=(1/h1)+(x/k)+(1/h2)
to determine the overall heat transfer coefficient U [W/m2K].
What are some reasonable values for the heat transfer coefficients h1 and h2? If we have these values we can calculate the heat flow Q [W] through the wall. For instance, using h1=60 W/m2K and h2=40 W/m2K, we get Q=U*dT=600 W.
Now say we want to put a thermal barrier coating on the hot side of the wall so that the wall temperature, Tw1, goes up by 10 K. The coating has a very low thermal conductivity of k=0.02 W/m,K. Is there a way to estimate how thick the coating needs to be to achieve this? Is there enough info to solve this, or do we need more numbers?
Does the heat transfer coefficient h1 change when we apply an insulation layer? Any help or tips would be greatly appreciated!
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
rsk2mc
rsk2mc is offline
#2
Dec19-11, 08:44 PM
P: 15
What type of heat transfer are you doing? Conduction,convection,radiation this is going to determine the equation. I'm not sure you are using the correct equation as I do nit know what type of heat xfer it is
Travis_King
Travis_King is online now
#3
Dec20-11, 07:47 AM
P: 764
Thermal Conduction
I haven't done much with insulation, and I don't really feel like crunching numbers, but you'll either have to pick a desired delta T (or Q or whatever you want) or you'll have to do iterations until you are satisfied. Excel worksheets usually work pretty well for stuff like this.
Register to reply
Related Discussions
Heat transfer problem - not given tube thickness Engineering, Comp Sci, & Technology Homework 2
Question about insulation and heat transfer Classical Physics 2
Questions about insulation and heat transfer General Physics 7
Heat Transfer from metal wall Engineering, Comp Sci, & Technology Homework 0
Effect of thickness on heat transfer/insulation Classical Physics 11
