Problem on quadratic polynomial.
The discussion revolves around a quadratic polynomial represented by the equation y=ax²+bx+c, with a focus on analyzing its graph and determining the validity of several statements regarding its coefficients based on the graph's characteristics.
  • Participants explore the implications of the graph's concavity and the conditions for real roots of the quadratic equation. They question the validity of statements regarding the coefficients a, b, and c based on the graph's behavior at the x and y axes.
The discussion is active, with participants providing hints and questioning each other's reasoning. Some participants have offered guidance on interpreting the graph's concavity and its implications for the coefficients, while others are still clarifying their understanding of the relationships between the coefficients and the graph's features.
Participants note that they are working within the constraints of their current educational level, which limits the use of advanced calculus concepts. There is also a recognition of the need to adhere to forum rules regarding the provision of complete solutions.
sankalpmittal
The graph of the quadratic polynomial , y=ax2+bx+c is as shown below in the figure :
http://postimage.org/image/nvkxv74yd/
Then :
(A) b2-4ac<0
(B) c<0
(C) a<0
(D) b<0
y=ax2+bx+c
If y=0 , then ax2+bx+c=0
Then ,
x = {-b+-sqrt(b^2-4ac)}/2a
Hmm tally image please...
When parabola is intersecting x-axis then y=0 and
Case 1 : x<0
Case 2 : x>0
if x >0 or x<0
then b2-4ac >0
So b2 > 4ac
Now what ...:confused:
Please help !
Thanks in advance. :smile:
You're thinking too hard. Think about the concavity of the graph (that is, the direction in which the parabola opens).
Thanks for a hint ex-mentor !
Parabola is opening in the -y axis direction , right ?
If A was correct:
it would mean that y=ax^2+bx+c =0 would have no real solution, which would mean that the y(x) would never be zero, which is wrong by the graph.
Wrong
If B was correct:
it would mean that for x=0 the y(x)=y(0) would take the value c <0 which by the graph is incorrect. y(0)>0.
Wrong
Now C :
You check y(x) derivative.
y'(x)= 2ax+b.
and from that we see that y'(0)= b.
Though since your MAXIMUM is at x=0, it means that y'(x) must be zero at that point y'(0)=0.
Wrong
Checking on D.
The way to see it is to look at its second derivative:
y''(x)= 2a.
you see from the graph that a has to be a<0 because of the concavity.
Right
Morgoth said:
If A was correct:
Wrong
If B was correct:
Wrong
Now C :
y'(x)= 2ax+b.
Wrong
Checking on D.
y''(x)= 2a.
Right
Please don't go so sophisticated. We haven't been taught limits and derivatives and integrals till now because I am after all in class 10th , 15 years. However your answer is correct and that was only given in answer key. Can it be done without involving introductory calculus ?
You are a new member. Please don't give full answer as its against forum rules. :redface:
Just alerting you.
Ups sorry...I didn't know...I will keep that in mind.
Oh well at least for the 2 firsts i think you don't need calculus.
Now the rests, you can check anytime.
Try drawing for example:
y=ax^2+bx+c
with a,b,c so that you will have your cases.
eg for case A it is y=x^2 + x + 1 b^2-4ac= -3 <0
and see how it works :) then see which one fits better
Hi sankalpmittal! :smile:
Let's try and categorize your drawing of the parabola a bit.
How many roots do you have?
And what consequence does that have for your solution formula?
At which x coordinate do you have the top of the parabola?
And at which side of the x-axis is the top?
Can you substitute that in the generic parabola equation and draw some conclusions?
You already saw it opens in the negative y-direction.
What happens if you substitute a very large x-value in the parabola equation?
What would the sign be of the resulting y-value?
Yes that's right. What, if anything, does that imply for the coefficients a, b, or c?
When x is very large, y is approx equal to ax2
Since x2 is going to be positive, the sign of y in this region tells you something about a.
Many thanks to NascentOxygen , Tom Mattson , ILS and Morgoth for their hints ! :smile:
I think I figured out this problem.
The first option A i.e. b2-4ac<0 is incorrect because that parabola is yielding real roots. Option A is out.
When that parabola is cutting the y-axis then of course x=0
So
this implies that
y=a.02+b.0+c
y=c
As we know from graph that y is positive so c is also positive. This implies that c>0.
But option B says that c<0 which is wrong. Option B is out.
Now when parabola is intersecting on first quadrant (+) of x-axis , then y=0 (we can also take -x axis also.)
so
0=ax2+bx+c
As we know that
m = Δy/Δx
We know from above equation
m = (y-c)/x where c is y intercept. As y = 0 then also c =0 because Δy=0 here. We aren't taking in account y intercept because its 0 !
This implies y=c=0
So we know b2-4ac>0 as its yielding real roots.
so b2-4.a.0>0
b2>0
or1
b>0
But option D says that b<0 which is incorrect as we found that b>0 so option D is out.
Now only option which is left is C which has to be correct because ,
as c=0
I get 2 values :
x= (-b+b)/2a
x=0
And
x= -2b/2a
x=-b/a
Now here x is positive because axis is +x. To make "x" positive "a" has to be negative as we know before that "b" is positive. This implies that a<0.
QED.
I got the correct answer but am I methodically correct ?
Thanks again !:smile:
So
this implies that
y=a.02+b.0+c
y=c
Yep and yep! :)
So c is the y-intercept of the parabola.
so
0=ax2+bx+c
As we know that
m = Δy/Δx
This implies y=c=0
Huh? :confused:
I do not understand.
Where did m = Δy/Δx come from?
And why would m = (y-c)/x where c is y intercept?
The tangent line would not have the same y-intercept as the parabola has...
c is not zero.
You already concluded it was greater than zero and that is was the y-intercept of the parabola...
I like Serena said:
Huh? :confused:
c is not zero.
I already concluded that c=0 because the parabola is not cutting y-axis when y=0 and x>0.
If I am wrong then what shall I do ? Any more hints...:confused:
Up to now I have found that option A and B are out.
Hmm so
0=ax2+bx+c
where b>0 and c>0
Now what.. :confused:
Also b2-4ac >0
Hmm so
0=ax2+bx+c
where b>0 and c>0
Also b2-4ac >0
You can't get more information from y=0 than you already have.
That is, that there are 2 solutions for y=0, which is expressed in b2-4ac >0.
Also, you can not conclude that b>0.
Let's inventorize:
1. the parabola intersects the positive y-axis at y=c, meaning c>0
2. the parabola intersects the x-axis at 2 points, meaning b2-4ac >0.
3. the parabola opens up downward, meaning...?
4. at which x-coordinate does the parabola have its maximum? And what to deduce?
Earlier you determined that c>0, and you did that correctly. So how can you now take another view, and say c=0?
Better go back and refresh your mind on the method that led to you getting it right.
y=ax2+bx+c
I like Serena said:
Let's inventorize:
Hmmm let me think a bit.
This question was for the standard of class 10th. I can't involve introductory calculus or parabolic equation ( c2 = x2+y2 ) here. I have to do it by applying simple coordinate geometry (up to 10th standard) only.
Anyways , when parabola is intersecting on positive quadrant of x-axis then ,
x = {-b+-sqrt(b^2-4ac)}/2a , but here I can't say that y=c>0 also. I have got myself totally confused and winded. :confused: If I am taking in account that option B that is c<0 wrong since c>0 and also y>0 then I can also take that in account here. I have got myself totally blundered now !
The concavity of parabola is downward meaning that y is negative and at one side x > 0 and y<0 AND at other side y<0 and x<0.
Now what can I do ? :confused:
Suppose we pick the parabola y=2x2.
It goes up doesn't it?
What would it take for the parabola to go down?
(I like your picture btw. :wink:)
<neat pic>
It's fortunate that this image is not in the list of available smileys, or writers here would find it applicable to almost every post on PF!
A quadrant is an area, one-quarter of the plane. You could phrase this better as, "where parabola intersects the positive x-axis then ...".
You could start by returning to my question which so far has not been answered:
For the equation y=ax2+bx+c, when x is very large, this becomes y is approx equal to ax2
Since x2 is going to be positive, yet in this region on the graph we see that y is negative, then the sign of y in this region tells you something about the sign of a.
You do overcomplicate the problem. Look at NascentOxygen's big formula:
y=ax2+bx+c
and compare with your drawing:
The curve intersects the y-axis at a positive y value.The points on the y-axis correspond to x=0. Therefore
c>0
A general parabola can be obtained from the standard y=X2 one by shifting it along x, y and multiplying by a number a as
[tex]y=a^2+bx+c=a\left((x+\frac{b}{2a})^2+(c/a-\frac{b^2}{4a^2})\right)[/tex]
If a is a negative number, the parabola is upside down with respect to the standard one. The standard one is open upward. Your parabola is open downward, so
a<0
b/2a shows the shift of the parable along the x direction. As I see, your parabola is not shifted.
ehild
Concavity of parabola is in the direction of -y axis. In y=2x2 , x2 is positive and so is 2 , so this equation is not satisfied if we compare it with the parabola going downwards as y is negative. You are asking me to use parabolic equation... y=ax2 where x2 is positive and y is negative , so "a" has to be negative.
This implies a<0 , isn't it ?
Thanks !
Answered , I think. See the above reply to ILS' post in my post.
y=ax2+bx+c
c>0
a<0
ehild
Ahh ! One more easier method ! Parabola is yielding real and distinct roots. So one value of x is positive and another is of course negative. So product of the two roots is negative as well.
P or Product of two roots = c/a
P = c/a
Since "P" is negative and c>0 so of course a<0 ! :smile: I couldn't help laughing !
Can this problem be solved without using parabolic equation ?
BTW , how can I say that b<0 i.e. option D is wrong ?
Thanks in advance.
Sankalpmittal,
This is a little exercise for you, to get the feeling about quadratic equations and parabolas. Look at the following quadratic functions and sketch them.
What is the product of the roots and the sum of the roots of the f(x)=0 quadratic equations? Find a, b, c for all of them. Find the position of the peaks. Discover how the position of the peak is related to the roots.
f(x)=x2;
f(x)=-x2;
f(x)=(x-2)2;
f(x)=(x+2)2;
f(x)=(x-2)(x+2);
f(x)=(2-x)(x+2);
f(x)=(x-1)(x-3);
f(x)=(1-x)(x-3);
f(x)=(x-1)(x+3);
f(x)=(x+1)((x-3);
f(x)=(3-x)(x+1).
(Snip)
Yep! :smile:
You seem to be picking things up nicely! ;)
Erm... all the answers are related to the parabolic equation...
So how would you deduce an answer without it?
I think the trick is to understand what the parameters mean geometrically.
Ehild's exercises should help with that.
And suppose you had simply y=bx+c.
What does it mean if either b<0, b=0, or b>0?
What happens if you add the extra term ax2?
"Can this problem be solved without using parabolic equation ?
BTW , how can I say that b<0 i.e. option D is wrong ?"
from your solutions x1,x2 you can see that b<0 would mean that:
x1= -b/2a + sqrt[b^2-4ac]/2a
x2= -b/2a - sqrt[b^2-4ac]/2a
[x1+x2]= -b/a => [x1+x2]/2 = -b/2a
so where would the mean value of your solutions (y(x)=0) lie? on which side of the x-axis acording to b and a signs?
Hope this can help a little bit more.
ehild said:
Note : f(x) = 0 for all equations given :
So here ax2+bx+c = 0
1. f(x)=x2;
Product of roots = c/a ; Sum of roots = -b/a
x=0
a=1 , b=0 , c=0
Sum of roots = product of roots = 0
2. f(x)=-x2;
x=0
a=-1 , b=0 , c=0
3. f(x)=(x-2)2;
x=2
a=1 , b=-4 , c=4
Sum of roots = Product of roots = 4
4. f(x)=(x+2)2;
x=-2
a=1 , b=4 , c=4
Sum of roots = -4
5. f(x)=(x-2)(x+2);
x= 2 , -2
a=1 , b=0 , c=-4
Sum of roots =0
Product of roots = -4
6. f(x)=(2-x)(x+2);
x= 2 , -2
a=-1 , b=0 , c=4
Sum of roots =0
7. f(x)=(x-1)(x-3);
x= 1 , 3
a=1 , b=-4 , c=3
Sum of roots =4
Product of roots = 3
8. f(x)=(1-x)(x-3);
x= 1 , 3
a=-1 , b=4 , c=-3
Sum of roots =4
9. f(x)=(x-1)(x+3);
x= 1 , -3
a=1 , b=2 , c=-3
Sum of roots =-2
Product of roots =-3
10. f(x)=(x+1)(x-3);
x= -1 , 3
a=1 , b=-2 , c=-3
Sum of roots =2
Product of roots = -3
11. f(x)=(3-x)(x+1).
x= -1 , 3
a=-1 , b=2 , c=3
Sum of roots =2
Now I am taking your 10th quadratic equation to plot the graph which is attached with the post , a bit too untidy:
f(x)=(x+1)(x-3)
f(x) = x2-2x-3
Let f(x) = y ,
y=x2-2x-3
Wow ! I see that in my graph concavity is in upward direction and so a>0 , b<0 and c<0 !
I like Serena said:
Yep! :smile:
Really ?!
if b<0 then
then x can be negative or positive and c>0.
y-c = Y is negative , so
Y=ax2+bx
then bx is positive or negative. If positive then a<0 , if negative then...:confused:
If b=0 then
Y=ax2
a<0
If b>0
then
Y=ax2+bx
then again same problem arises as in case b<0 !:confused:
How about this method :
P = c/a
Mean value lies in +x axis according to parabola in post 1.
[x1+x2]/2>0
So -b/2a >0
b>0
if we solve like
1/2a >0
then it would be like a>0/0 which is indeterminate.
So b>0
Now ,
-b/2a >0
Now this implies a<0 !
Am I correct ?
no you are not correct.
when you said b>0 and said 1/2a>0 why did you then type a>0/0? And don't forget the inequality properties. What happens to the inequality sign when you multiply both sides with a (-).
(-1)*b/2a = -b/2a>0 means that b/2a<0 (two negative numbers [-1 and b/2a<0] multiplied will give you a positive one).
so if a>0, b<0.
if a<0, b>0.
Otherwise if they had the same sign you would have [itex]\frac{+}{+}[/itex]= + >0 or [itex]\frac{-}{-}[/itex]= + >0
And you cannot use what I typed above in a diagram that doesn't have the x-axis calibrated correctly. I just said that for one more calculus way to find the sign of b, knowing the one of a, and not to answer your question but try to give you one additional help of understanding.
so if a>0, b<0.
if a<0, b>0.
Oops !:redface:
My method is wrong but not the result.
I know [x1+x2]/2>0
So -b/2a >0
This means that -b/2a as a whole is a positive value , isn't it. So if I square on both sides then signs will obviously not change !
(-b/2a)2 >(0)2
b2/4a2 > 0
So b2>0 => b>0
Hence in -b/2a >0
a < 0 !
Your method is easy I see.:smile:
better than squaring- when you have something like:
-(something)> (else)
do:
(-1)*(-something)<(-1)*(else)
so (something)<-(else)
if (else)=0 and something here will be (something)=b/2a
you have:
-b/2a>0
means
b/2a<0
you have understood how to find a's sign so you know that a<0 or a>0 so respectively b>0 or b<0
f(x)=(x+1)(x-3)
f(x) = x2-2x-3
Let f(x) = y ,
y=x2-2x-3
Really ?!
Why are you surprised?
I send you a bunch of parabolas to get familiar with them. Notice that they are symmetric, the axis of symmetry is parallel to the y-axis and goes through the peak, and the peak is halfway between the roots. Notice that the concavity depends on the sign of the multiplier of x2 alone.
Which parabola is most similar to the one in your original post?
ehild
do:
you have:
-b/2a>0
means
b/2a<0
Morgoth , I know rules of inequalities. By squaring on both sides I can easily get that b>0 and a<0. If I mess up with - sign here then condition become not so obvious : either a>0 and b<0 , OR a<0 and b>0.
ehild
I guess that the parabola in somewhat light blue colour is the approximate match of my parabola in post 1 : https://www.physicsforums.com/attachment.php?attachmentid=42155&d=1324617111
Not quite right. Squaring is going to mix up everything in your mind, because even if you square -1 you will get +1, and then will you go tell that -1>0 because its square is (+1)>0?
Because that's what you do when you type me:"So b2>0 => b>0" in your previous post.b2 >0 (for b in ℝ) means that b<0 or b>0 but surely not 0.
So be careful when squaring. Another thing is that you have:
+4 > -6
squaring:
16 > 36 ?Another example:
-1 < 0
squaring:
1<0 !and one last for another reason:
let's say you have one number A and one number B, for which you know that their squares will also follow the below rule:
A2 > B2
What you can say for A and B?
the above rule tells you that:
A>B
or
A<-B
for example on this is to try find which number x is:
x2 > 2
the answer is that:
x<-√2 or x>+√2
x2<2
gives
-√2 < x < +√2
even when you have equalities it is being difficult.
If you have tha a=b then you can say that a2=b2 here without a problem (as there was with -1<0 above)
On the other hand
if you have that a2=b2 then you write that a= ±b.
Your parabola in post #1 is not a real parabola but it has maximum at x=0. So it must be symmetric to the y axis. It would be useful to see the original picture or a better copy of the original.
If the maximum is really at x=0, what is b then?
ehild
  • · Replies 19 ·
  • · Replies 19 ·
