| Thread Closed |
A Case for the 4-D Space-Space Block Universe |
Share Thread | Thread Tools |
| Dec22-11, 06:06 PM | #35 |
A Case for the 4-D Space-Space Block UniverseEdit: Ok, I see that the last paragraph of the post is supposed to be the excerpt. It would still be nice to have a link to the entire review. |
| Dec22-11, 06:17 PM | #36 |
![]() The wording of the description of Godel's "remarkable proof" is already a red flag: the author is being way too dogmatic about what Godel's proof "means". The author appears to be a philosopher, not a physicist, which IMO is another reason to take what he says about the application of such proofs to physics with a grain of salt. John Stachel, a physicist, reviewed the book, and his review is online here: http://www.ams.org/notices/200707/tx070700861p.pdf He appears to have similar misgivings about the author's flat assertions about what Godel actually proved. This review, btw, also has an interesting quote from Einstein: "Time and space are fused in one and the same continuum, but the continuum is not isotropic. The element of spatial distance and the element of duration remain distinct in nature…" |
| Dec22-11, 07:04 PM | #37 |
However, I have a hunch that more and more physicists--at least among those interested in the subject at all--are beginning to have second thoughts about the concept of time and the 4th dimension in special relativity. Probably most physicists are too involved in their own specialty to give much thought to these questions. My advisor certainly thought it a waste of my time to worry about it. He had no time for those kinds of discussions, and he devoted all of his time to relativity and published often in Phys Rev. One should not lose track of the requirement that material objects must extend into the 4th dimension if different observers simultaneously exist in different cross-sections of 4-D, each including different instantaneous 3-D volumes of the same 4-D object. And it is not comprehensible that those different 3-D volumes are made of some kind of mixture of space and time--they must indeed be cross-sections cutting across at different angles. (see my sketch illustrating this in the very first post of this thread) There is no argument about whether the cross-sections are spatial--they are of course--X1', X2', and X3'. How you could get those different 3-D volumes to all come out as spatial in all three dimensions when they were cut at totally different angles from a 4-D object without a spatial quality in the 4th dimension defies logic. I don't think you can cite a reference where Einstein dismissed the notion of 4-D objects. What would it mean to have a 4-dimensional object whose 4th dimension is not spatial? The reason the continuum is not isotropic is because of the way 4-D objects extend into the spatial 4th dimension (X4)--extending billions and trillions of miles--as compared to the relatively miniscule extent along X1, X2, and X3. And then the consideration of the different relationships of X4 and X1 with respect to the light cone. |
| Dec22-11, 08:30 PM | #38 |
PeterDonis, You never did offer an explanation as to how you could have simultaneous different cross-section views (by two different observers) of the same object unless that object was actually a 4-dimensional object.
| Dec22-11, 08:32 PM | #39 |
What we actually observe is what is in our past light cone, and in so far as objects we interact with must "extend into the 4th dimension", all we can directly observe is that they extend into our past light cone. As we look further into the past, we can consider intersections of the interior of our past light cone with surfaces of "constant time" as being snapshots of a portion of "space" at that time in the past, but it's still only a portion, and the "space" is still a mathematical construct. The same goes for the different "spaces" that are formed by slicing through our past light cone at different "angles", as would be done by someone just passing by us now at some appreciable relative velocity. This sort of thing is what I think Stachel was getting at when he talked about "time" being local. Once you have the mental model of spacetime as a "stack" of 3-D spaces formed into a single 4-D manifold, it's natural to ask questions like "what is happening in the Andromeda galaxy *right now*"? But these questions have no well-defined physical meaning. Once you realize that different states of motion correspond, in the model, to "slicing" the 4-D manifold into a stack of 3-D spaces at different angles, it's natural to ask further questions like "since what time 'now' is in the Andromeda galaxy can change depending on how I'm moving, doesn't that mean that the whole, entire worldline of the Andromeda galaxy must already 'exist', so the Andromeda galaxy really extends through the 4th dimension as well as the other three"? But those questions don't have any well-defined physical meaning either. As I said in an early post in this thread, I view the "block universe" as a *model*, not as a claim about "reality". As a model, it clearly distinguishes between X4 and the other three dimensions. |
| Dec24-11, 08:14 PM | #40 |
I don’t think Stachel thought carefully through Godel’s position. Of course we must acknowledge that it is possible that it is not true, i.e., the assertion that objects exist as 4-dimensional. I have no problem with that. It’s just that a spatial 4th dimension seems more natural than a time 4th dimension. For the realists, the thrust of physics is comprehending what is “out there” as something physically real, existing as a space populated by “real” objects. It is not necessary to observe those objects to know they are there if measurements along with supporting analysis sufficiently imply an existence. And that extence concept must at the very least be compatible with special and general relativity. This is in contrast to the idealistic notion of “things” existing in the mind (a concept dangerously close to solipsism). My graduate philosophy of physics professor told our class that the class room next door did not exist until he entered that room and observed it (nothing exists unless it is being observed). He had PhDs in physics and philosophy and seemed to be a disgruntled ex-physicist. He was always in attendance at our physics department Friday colloquium. So it seems that you reject the concept of the simultaneous volumes (“planes”) of simultaneity described by special relativity. That would seem to imply that you would reject the concept of time dilation and length contraction. Particularly length contraction, since both ends of the beam in the simultaneous space of special relativity could not be observed simultaneously. When starting this thread, I probably should have stipulated that we are only interested in discussing the relative merits of a 4th dimension having the essence of space as compared to the 4th dimension having the essence of time--and discussing this with the stipulation that, either way, we base our discussion on the assumption that we have accepted the concept of a real objective external world. That means we would agree that every observer experiences existence in an extended real external world of 3 dimensions. The point I’ve been trying to make is that, given that every observer occupies an external 3-dimensional world, and given the theory of relativity, then a spatial 4th dimension is implied. I agree with you that if you cannot assume a real external world for a given observer, then the kind of analysis we've been doing here is not meaningful. |
| Dec24-11, 09:09 PM | #41 |
For example, suppose red fires a rocket between R1 and R2. Blue has been keeping track of red's motion and, when blue and brown pass, blue sends brown a message saying that red is at R1 simultaneous with their crossing, in blue's frame. Brown knows his velocity relative to blue, so he can calculate that red is at R2 simultaneous with the crossing in brown's frame. But when brown receives light signals that red emits after R1, he will see that his calculation was wrong: red's worldline never actually goes through the event R2, and if brown reconstructs his surface of simultaneity at the event where he passed blue, he will find, on the basis of later light signals, that red actually crossed that surface at some other event, R3. The point of all this is that the view that red's worldline between R1 and R2 must "already exist" when blue and brown cross is a *model*, not reality; and the model may need to be updated as more data comes in. In theoretical problems, when we're just trying to study the logical implications of a model, we can stipulate that things like red firing his rocket don't happen; but in the real world, we can't do that. We have to recognize that there is always more data that hasn't come in yet about what is happening "now" outside our past light cone; and until we receive that data, we can't treat those events as having "happened". |
| Dec24-11, 09:32 PM | #42 |
| Dec26-11, 04:46 PM | #43 |
It seems that there is this concept that one cannot know that he is existing in a volume (plane) of simultaneity, because the only things experienced (observed) directly in the mind are thoughts based on information arriving from the past. There is no external existence within ones instantaneous Lorentz space that can be directly observed until sometime later—then it is too late—it is already in your past by then. This idea is certainly compatible with the Vienna logical positivist school and gave strength to the idealists like Berkeley who maintained that reality existed within the mind (ultimately, the mind of God). The idea is favored by solipsists as well (Einstein warned about falling into the trap from which there would be “…no escape from solipsism”).
Here, we will appeal to Hawking’s more flexible approach he refers to as “model-dependent realism: the idea that a physical theory or world picture is a model (generally of a mathematical nature) and a set of rules that connect the elements of the model to observations. This provides a framework with which to interpret modern science.” This is from “The Grand Design” by Stephen Hawking and Leonard Mlodinow. Actually, PeterDonis, I believe the ideas you are advancing here are generally much more in line with Hawking. So, I should not be accusing you of advocating logical positivism or solipsism. (Perhaps I owe you and apology on that count.) So, here is a space-time diagram with a sequence of events. The diagram represents a sort of sequence of thought experiments in which observers in a Lorentz space send messages back and forth as they move through 4-dimensional space. At the end of the sequence of experiments, they get back together and compare notes to see if there is a basis for knowing that each other existed in any of the Lorentz space simultaneous external world volumes. In the sketch below the brown, light brown, and blue observers are together. They are initially together in the brown rest frame, synchronizing space-time markers, displays of actual distance traveled in 4-dimensional space, referenced from a point assigned as zero distance. The distances displayed (and photographed at selected points) will correspond to distances traveled along the respective world lines. All three are together at event 1 (events in the space-time diagram are brown, light brown, or blue circles) where they synchronize their distance markers). It is planned that the light brown guy and the blue guy will move to a new position that puts them in brown’s instantaneous plane (3-D volume) of simultaneity at event 8. Light brown and blue have used Lorentz transformations to assure that their distance markers display the same values at event 8 as the brown guy’s markers display at event 2. Light brown and blue both transmit pictures of their displayed values so that brown can validate their numbers when he (brown) arrives at event 3 in the space-time diagram (brown calculates how far he has traveled along the 4th dimension since leaving event 2. At event 9 the light brown guy transmits a photo of his distance display, which is received by blue at event 14 and received by brown at event 4. The blue and brown guys do calculations that demonstrate that events are still occurring in agreement with theoretical physics. At this point the brown guy is able to confirm that the light brown guy existed in his plane of simultaneity back when he (the brown guy) was at event 3). From the data received from the blue guy at event 4 he is also able to determine that the blue guy was also in his (brown’s) plane of simultaneity back at event 3. ![]() Just one experiment doesn’t seem enough, so they continue acquiring data. The blue guy arrives at the brown guy’s position at event 5. So, here the blue guy and the brown guy simultaneously occupy the same position at the intersection of their X4 axes. Special relativity tells them that if the light brown guy really still exists, then the light brown guy must exist at event 11 in blue’s instantaneous 3-D space volume, while simultaneously existing at event 12 in brown’s simultaneous space. However, as PeterDonis points out, they can’t really be sure, because they have no way of getting information from those events instantly while they are at event 5. They must wait until later for confirmation from the light brown guy. Brown gets his confirmation when he arrives at event 6, receiving the picture of light brown’s event 12 photo of his distance traveled along the 4th dimension, which is exactly the same distance that the brown guy recorded for his own trip when at event 5. Thus, brown concludes that the light brown guy must have been in his simultaneous space which included both event 5 and event 12 simultaneously. The blue guy has to wait until his event 16 for confirmation that light brown was at event 12 simultaneously with event 5 (when both blue and brown guys were simultaneously at event 5). Of course the blue guy saved a copy of brown’s distance position along brown’s X4 dimension when they were together at event 5. So, now he had confirmation that light brown was in brown’s simultaneous space, i.e., both brown and light brown were in the simultaneous space of events 5 and 12. But, now, blue asks whether the light brown guy was in his (blue’s) simultaneous space when blue was at event 5. Fortunately, light brown included a photo of his X4 position corresponding to event 11. Light brown and blue both used Lorentz transformations to figure out what each other’s positions should be along their respective X4 axes when blue arrived at brown’s position, event 5. Light brown transmitted his computations that he had made about what blue’s X4 position should be when light brown was at event 11. And blue computed the X4 reading that light brown should have when he (blue) was at event 5. Light brown and blue wanted to be sure science was working right, so they took photos of their respective X4 distances corresponding to blue’s simultaneous space at blue’s event 16. Light brown did calculations (by prearranged agreements) at event 13. At event 17 blue found that light brown was in his (blue’s) simultaneous space when blue was at event 16 and light brown was at event 13. Without including it in the space-time diagram we have all three observers get together at the end of the experiments and review all of their data. They conclude that sure enough, when the brown guy and blue guy were at event 5, the light brown guy simultaneously existed at event 12 (in brown’s simultaneous space) and event 11 (in blue’s simultaneous space). They then conclude that the light brown guy is actually a 4-dimensional object, and-- by extension--they all are. Thus, we have a model in which objects are 4-dimensional extending into a 4th spatial dimension. Further, once it is recognized that we have a 4-dimensional spatial universe populated by 4-dimensional objects, it is obvious that the objects do not move. There is a perception of motion related to 3-dimensional cross-sections of the 4-dimensional objects, and this is compatible with the notion of consciousness moving along the 4-dimensional world line of an observer, the consciousness having a deep connection to the perception of the "flow of time." Finally, it implies two possible models of consciousness: 1) A 3-D consciousness that moves at light speed along the observer's world line, or 2) A 4-D consciousness that is coupled to the 4-dimensional material structure of the observer over the full extent of the observer world line. These experiments (albeit thought experiments) would satisfy the criteria for a good model fit, at least in agreement with Hawking’s criteria: 1. Is elegant 2. Contains few arbitrary or adjustable elements 3. Agrees with and explains all existing observations 4. Makes detailed predictions about future observations that can disprove or falsify the model if they are not borne out. To satisfy number 4 in a more convincing manner, The three observers could have sat down together and planned the entire set of experiments in advance, predicting all of the readings that would be observed at each of the events in the scenario.
| Dec26-11, 07:54 PM | #44 |
I have no problem in general with your scenario; as you've specified it, all three observers could, as you say, plan the whole sequence of experiments in advance, and (provided nothing external interfered) collect the data to confirm that their model was correct. The only thing I would add is to take note of that parenthetical statement I put in about something external interfering. In the real world, there is always the possibility of something external interfering, and when that happens, we can't know about it until light signals from the external event reach us. For example, suppose that, when brown, light brown, and blue actually run the experiments as you specify, something unexpected happens: a powerful laser pulse comes in from the negative x direction and hits light brown at event 12. The impulse of the laser pushes light brown into a new trajectory that is moving to the right (i.e., in the positive x direction) with the same velocity as blue, relative to brown. Light brown knows immediately at event 12 that his trajectory from event 12 on will not match what they all predicted before the experiments were begun. But brown will not know this, and will not be able to base any predictions on it, until event 6, when he sees the light from event 12 and realizes he was hit by the laser pulse. And blue will not know it until event 16, when the light from event 12 reaches him (and of course brown can't send him a signal any faster). Now, how will brown and blue reconstruct the effect of the laser pulse? Brown, reconstructing events after he sees the light pulse from event 12, will say that light brown was hit by the laser simultaneously with event 5, i.e., at the same time as brown and blue were passing each other. But to blue, event 5 happens *before* event 12, so even though blue and brown are co-located at event 5, they will not agree on whether or not light brown had been hit by the laser pulse "at the same time" as they were passing each other. This is why statements like "event A and event B happened at the same time" can't have any physical meaning unless they are qualified (by referring them to a specific observer's frame); two observers can disagree on them without having any way of settling their disagreement by making any further observations. |
| Dec26-11, 08:48 PM | #45 |
One has to be careful with the language. I agree that when we say that the two observers, blue and brown, are together at "the same time," different people could come away with different interpretations about the meaning of that phrase. In this instance it certainly does not mean that the blue guy and red guy would each be reading the same proper time on their world line clocks--we can't use the phrase "same time" in that sense (just as we have different "age times" in the reunion of the twin paradox). But, there is no confusion in understanding that there are two different events, 11 and 12, and that as blue and brown exist together (next to each other), event 11 is in brown's world but it is not in blue's world; and event 12 is in blue's world but it is not in brown's world. And it would appear that we can only have such a circumstance if the light brown object is 4-dimensional (allowing different 3-D cross-section views) and extends into the 4th dimension. |
| Dec26-11, 09:54 PM | #46 |
Blue and brown can build *models* of their "worlds", and in those *models*, yes, event 11 is "in blue's world at event 5" but event 12 is not, while event 12 is "in brown's world at event 5" but event 11 is not. But those models are just that, models; the "worlds" in them do not have to be "real worlds" in order to serve their function as models. There are certainly "real events" 11 and 12, but blue and brown, at event 5, *don't know* what those actual, real events are; they only know what their models say about them. It may well seem that I'm belaboring this, but I'm only doing so to make what I think is a fundamental point about what the "block universe" model does or does not claim. As I understand it, the "block universe" model does *not* claim that, for example, events 11 or 12 have to be "real" or have "actually happened" from blue or brown's point of view at event 5. All that the "block universe" model requires is that blue and brown have a *model* of events other than those along their own worldlines, such as events 11 and 12; in other words, blue and brown have a *model* of light brown traveling along his worldline, and that model will recognize that different events on light brown's worldline (11 and 12) are seen as "simultaneous" to blue and brown at event 5. But the model must also recognize that no physical experience blue or brown can have at event 5 can possibly be affected by what happens at events 11 or 12, so there is no need or reason for blue or brown to claim that events 11 or 12 have "already happened" or "are happening *now*" at event 5. Similar remarks apply to what blue or brown might say after receiving light signals from event 12 showing the laser pulse hitting light brown and changing his motion. Blue or brown can certainly reconstruct events and show that event 12 was simultaneous with event 5 in brown's frame, but happened *after* event 5 in blue's frame. But what, if anything, should they conclude from this? My answer is, nothing of any consequence. The fact still remains that no physical experience blue or brown could have had at event 5 could possibly have been affected by what happened at event 12. In other words, these 3-D "worlds" you are talking about, as tempting as they are conceptually to our intuitions, are actually not the right things to concentrate on, even in the "block universe" model. The crucial "boundaries" in spacetime are not surfaces of simultaneity, but light cones; and the crucial relationships between events are not simultaneity relationships but causal relationships--timelike, spacelike, or null separation. Events 11 and 12 are both spacelike separated from event 5, and *that* is the crucial fact about them. The "block universe" model is not supposed to change that. |
| Dec26-11, 10:19 PM | #47 |
When blue and brown are next to each other, either the light brown guy exists as a real world object or he doesn't. Then, if he does exist in the real external world of blue and brown when they are next to each other, one must reconcile the data that shows light brown existing in the real world of blue as well as the real world of brown. All of the data they analyzed after the fact leads to the conclusion that the light brown guy existed at events 11 and 12, even though it was impossible for blue and brown to confirm that at the time when blue and brown were next to each other and in their respective planes of simultaneity. |
| Dec26-11, 10:37 PM | #48 |
Mentor
bobc2, I have noticed references by you to the idea that it is possible to nave a non-positive definite metric in four spatial dimensions. Do you have a mainstream scientific reference for that.
I always thought that a non-positive definite metric implied at least one spatial dimension (positive signature) and one temporal dimension (negative signature). I don't see how you can possibly get a non-positive definite metric if they are all spatial and therefore all have a positive signature. |
| Dec27-11, 12:18 AM | #49 |
Whereas my answer is, it doesn't matter. The latest event on light brown's worldline that blue and brown can have direct evidence of at event 5 is the event where light brown passes through event 5's past light cone. *All* of light brown's worldline beyond that is unknown to blue and brown at event 5. That's the physical fact. That does not mean that portion of light brown's worldline does not "exist"; it simply means that blue and brown, at event 5, don't *know* what that portion of light brown's worldline consists of. That means that there are things that our normal, conventional ways of speaking would lead blue and brown to say, at event 5, that from the standpoint of physics, simply can't be said from their actual knowledge at that event. For example, suppose the laser pulse I postulated hits light brown at event 12 and destroys him, instead of just changing his motion. Brown and blue, when they later find out about this, would have to disagree, if they follow your prescription, about whether light brown was killed "at the same time" as they passed each other. Brown would say yes, he was killed at that time; blue would say no, he wasn't killed until "later", so at that event, light brown was "still alive". But if you were blue or brown, would you care? The primary fact about event 12 as it relates to event 5, as I said before, is that the two are spacelike separated; nothing blue or brown could do at event 5 would have kept light brown from getting killed at event 12. Given that inescapable fact, if you were blue or brown, would you bother arguing about whether light brown was killed "at the same time" as you passed each other, or not? The point of all this is that when you assert what you asserted in the quote above, you are asserting something whose truth might depend on events outside blue or brown's control at event 5. Brown, on your view, would have to say that no, light brown did *not* exist as a real-world object when brown and blue passed; he had just been killed that instant. Whereas blue, on your view, would have to disagree, and say that no, light brown *did* exist as a real-world object when brown and blue passed; he wasn't killed until "later". But on my view, if they are arguing about this at all, they are missing the whole point; they are arguing about something for which there simply is no invariant "fact of the matter"; whether light brown still "existed" at event 5 is frame-dependent. |
| Dec27-11, 09:30 PM | #50 |
It is interesting to me that of the large number of references I've encountered on the subject of block universe, four-dimensionalism (a philosopher's favorite), presentism, eternalism, etc., it is quite rare to see an author explicitly refer to the 4th dimension as "spatial." You often find comments about 3-dimensional objects physically extending into the 4th dimension, but that 4th dimension is usually identified only as time (if identified explicitly at all). It has always seemed elemental to me that if you have a material object extending into a 4th dimension, maintaining its material character with the extension, that 4th dimension would necessarily be spatial. That does not mean that you could not have time associated with that dimension in some manner (consciousness coupling, etc.), but how do you have a material 4-D objects existing without the 4-dimensional space? But back to your question. I don't think the indefinite metric specifies the essence of the 4th dimension. That signature is there because it is required to give you the orientation of the X1 coordinate and X4 coordinate with the constraint that they must always be rotated symmetrically about the worldline of the photon. That orientation has nothing to do with whether X4 is time or spatial. The other geometric aspect of that is that nature has populated 4-dimensional space with 4-dimensional objects that are billions and trillions of miles long, always oriented in a 4-dimensional direction confined to the inside of a light cone. So, it's these geometric aspects of the 4-dimensional world that account for the special nature of the 4th dimension. So, the signature of the metric is required to account for the geometry, and our measure of 4-dimensional distance (interlinked with our physics, the conservation laws) in this unusual 4-D world. |
| Dec27-11, 09:57 PM | #51 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: A Case for the 4-D Space-Space Block Universe
| Sample Space for Free Particle in the general case | Quantum Physics | 4 | ||
| Topological space, Euclidean space, and metric space: what are the difference? | Calculus & Beyond Homework | 6 | ||
| Curvature of space, universe | Astrophysics | 0 | ||
| Age of The Universe - Time vs Space | Cosmology | 8 | ||
