Compressional stress & shear stress
The discussion focuses on calculating compressional and shear stress on a square bar subjected to a force of 500 N at an angle of 37 degrees. The compressional stress is determined using the formula Compressional stress = Force/Area, resulting in 12,500 Pa, while shear stress is calculated as Shear stress = Force/Area x sin(angle), yielding 7,520 Pa. The area of the bar is converted from 4.0 cm to 0.04 square meters for accurate calculations. Both stress values are within the elastic limit of most materials, indicating that the bar will revert to its original shape upon force removal.
  • Understanding of compressional stress and shear stress concepts
  • Familiarity with the equations for stress calculation
  • Knowledge of cantilever beam mechanics
  • Basic trigonometry for force component resolution
  • Study the equations for cantilever beam deflection
  • Learn about the elastic limit and material deformation
  • Explore the concept of superposition in stress analysis
  • Investigate the effects of different angles on shear stress calculations
Engineering students, material scientists, and professionals involved in structural analysis and design, particularly those focusing on stress calculations in materials.
petep
A force of 500 N is applied at an angle of 37 degrees to the surface of the end of a square bar. that surface is 4.0 cm on a side. what are the compressional & shear stress on the bar? material processing class and i don't know the equation or where to start someone help please
You need to specify more information on this problem. What are the boundary (fixed point) conditions, i.e. is it a cantilever beam (one end fixed, one end free)? I assume that is the geometry for this problem.
Also I presume the horizontal component of the force vector is pointing toward the fixed end, in order to put the entire beam in compression.
So assuming it this is a cantilevered beam, what are the equations for a cantilever beam in deflection? Think of the horizontal and vertical components. You may ignore torsion.
Are you familiar with superposition?
Compressional stress is a type of stress that occurs when a material is being pushed or compressed from opposite ends, causing it to become shorter and thicker. This type of stress is typically seen in structures such as columns or pillars. On the other hand, shear stress is a type of stress that occurs when a material is being subjected to forces that are parallel to its surface, causing it to slide or deform.
To calculate the compressional and shear stress on the bar in this scenario, we can use the following equations:
First, we need to convert the given surface area of the square bar from centimeters to meters, as the SI unit for area is square meters. This gives us a surface area of 0.04 square meters.
Next, we can plug in the values into the equations. For compressional stress, we have a force of 500 N and an area of 0.04 square meters. This gives us a compressional stress of 12,500 Pa.
For shear stress, we need to first find the component of the force that is parallel to the surface of the bar. This can be done by using the sine function to find the opposite side of the triangle, which represents the component of the force. We have a force of 500 N and an angle of 37 degrees, so the component of the force is 500 x sin(37) = 300.8 N.
Plugging this value into the equation for shear stress, we have a force of 300.8 N and an area of 0.04 square meters. This gives us a shear stress of 7,520 Pa.
In conclusion, the compressional stress on the bar is 12,500 Pa and the shear stress is 7,520 Pa. It is important to note that these values are within the elastic limit of most materials, meaning that the bar will return to its original shape once the force is removed. If the stress exceeds the elastic limit, the material will undergo permanent deformation.
10K
