Help with apparent weight problem
The discussion revolves around a physics problem related to centripetal force, specifically concerning the apparent weight of a pilot in an airplane pulling out of a dive in a vertical circle. The problem involves calculating how many times greater the apparent weight is compared to the true weight, given specific parameters such as the radius of the circle and the speed of the airplane.
  • Participants discuss the definition of true weight and its relation to normal force and gravity. Some express confusion about the problem setup and the importance of the airplane's position in the loop. Others attempt to relate centripetal acceleration to the forces acting on the pilot.
The discussion is ongoing, with participants exploring different aspects of the problem. Some have provided insights into the relationship between centripetal force and weight, while others are seeking clarification on the problem's parameters and how to approach it.
There is a lack of specification regarding the airplane's position in the vertical loop, which may affect the calculations. Participants are also navigating the constraints of an impending test and the need for a clearer understanding of the concepts involved.
vee123
I need help with a physics problem ASAP please :)
I am currently in AP Physics and we are studying centripetal force. My teacher gave me a problem that is driving me crazy because I don't know where to begin with it, and I have a test tomorrow...
Here's the problem:
An airplane pulls out of a dive in a vertical circle of radius 1.0 km traveling with a speed of 550km/h. How many times greater is the apparent weight of the pilot than his true weight?
Can someone please help me?
The true weight would be your weight if you were standing on the surface of the earth. This is because your weight is the normal force acting on you. If you were just standing on the surface, the normal force would oppose gravity which is the only other force acting on you. Thus, your weight would be the force of gravity, mg. In this situation, why would that be any different?
vee123 said:
I am currently in AP Physics and we are studying centripetal force. My teacher gave me a problem that is driving me crazy because I don't know where to begin with it.
Here's the problem:
Any suggestions?
Here's another hint: It's important where in the loop the plane is (does the question specify that?)
It doesn't specify where in the loop the plane is. I just want to know how to get through this problem. I'm so confused! :(
[tex] F = ma_c[/tex]
and
[tex]a_c = v^2/r[/tex]
so the ratio between the centripetal Force and the normal weight 9.8m is
[tex]\frac{m(v^2/r)}{9.8m} = \frac{1980000000}{1000*9.8} = 19800[/tex]
9K
10K
