Solve Volume of Revolution Problem: y=x^{-2} to y=e Rotating Around Y-Axis
  • Thread starter Thread starter vilhelm
    Revolution Solids
The problem involves calculating the volume of revolution generated by rotating the area between the curve y=x^{-2}, the line x=1, and the line y=e around the y-axis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the problem, including the identification of outer and inner radii for the volume calculation. There are attempts to clarify the bounds of integration and the interpretation of the area being rotated.
Participants are exploring different methods for calculating the volume, with some suggesting simpler approaches while others express a desire to understand the formula being used. There is recognition of potential confusion regarding the setup and the roles of different radii.
Some participants question whether the area of interest is above the x-axis and discuss the implications of this on the volume calculation. There are references to drawing diagrams to aid understanding, and a mention of discrepancies in results from different methods.
vilhelm
Problem
The area between [tex]y=x^{-2}[/tex] and x=1 & y=e is rotating around the y-axis. What is the volume?
Attempt
[tex]\pi\left( r_{outer\mbox{}} \right)^{2}\; -\; \pi \left( r_{inner\mbox{}} \right)^{2} \; \; \; \delta y[/tex].
[tex]\frac{1}{x^{2}}=y\; gives\; \frac{1}{y}=x^{2}\; and\; r=\sqrt{y}[/tex]
[tex]V=\pi \int_{1}^{e}{\frac{1}{y}-1\; dy}[/tex]
Can I assume that the question means the area above the x axis?
Anyway, firstly you must draw the graph. Are you trying to find the volume of the cylinder then subtract the volume not included in the region? If so isn't the x=1 the outer radius? And so then rather the inner radius should then be (1-x)
I find it easier and a nicer integral to just sum the volumes - so calculate the volume generated by the cylinder from y=0 to y=1, and then add to this the volume generated by the curve from y=1 to y=e. Hopefully this helps
Yes, that would be more effective. I am, however, trying to learn this formula, and would like to use it on this problem.
It is indeed the area over the x-axis. The upper bound is e, the right side is x=1, and the third line is x^-2. If you see what I mean…
I don't follow when you say "If so isn't the x=1 the outer radius? And so then rather the inner radius should then be (1-x)"
Sorry for lag reply. Oh my god I've just spent the last 30 min scribbling furiously away at my desk because I was getting different answers from 2 different methods and didn't know why. When I did your way I got it wrong because the algebra was more complicated. So YEAH I really recommend just doing it the simplest way.
I shall now guess what you're trying to do. Are you trying to find the volume of the cylinder from y=0 to e made by a rotation, and subtract from this the volume generated by the unwanted area (between y=1/x^2, y=e and x=1)?
Okay, if so, what you've done is switch the 1 and 1/y. When you draw the diagram (draw a nice big one!), you will see that x=1 is the OUTER radius, and the inner radius is x.
So an infinitesimal thickness disc would have volume [tex]dV = \pi (1^2-x^2)dy[/tex]. Now since [tex]x=\frac{1}{\sqrt{y}}[/tex], then simply complete the integral, subtract this from the area of the cylinder, and the answer should be [tex]2\pi[/tex] cubic units!
  • · Replies 20 ·
