Standardization of H2O2 Solution
  • Thread starter Thread starter mousesgr
    standardization
The discussion revolves around the standardization of hydrogen peroxide (H2O2) solution through titration with sodium thiosulfate (Na2S2O3). Participants explore the reasons for variations in titration results between trials, the role of Na2S2O3 in the reaction, and the implications of the stoichiometry involved in the reactions.
  • Experimental/applied
  • Some participants question why the volume of Na2S2O3 used in trial 2 is greater than in trial 1, suggesting potential issues with the determination of the endpoint during titration.
  • Others propose that the difference in titration results may not be due to endpoint determination, as all classmates reported similar results.
  • One participant suggests that residual iodine in the conical flask could lead to positive errors in the titration results.
  • Participants discuss the role of Na2S2O3 as a reactant for iodine, indicating that it is used to indirectly determine the moles of hydrogen peroxide present.
  • There is a question regarding the stoichiometry of the reactions, specifically how the volume of thiosulfate used relates to the concentration of H2O2.
Participants express differing views on the reasons for the variation in titration results, with no consensus reached on the underlying cause. There is also uncertainty regarding the implications of the stoichiometric relationships in the reactions discussed.
Some participants note the importance of rinsing the conical flask between trials to avoid contamination, which may affect results. The discussion also highlights the need for clarity on the definitions and calculations related to the concentration of H2O2.
This discussion may be of interest to students and educators involved in chemistry experiments, particularly those focusing on titration techniques and the standardization of solutions.
mousesgr
H2O2 (aq) + 2 I-(aq) + 2H+(aq)------> I2 (aq) + 2 H2O(l)
2 S2O32-(aq) + I2 (aq) à 2 I-(aq) + S4O62-(aq)
i want to know
1.why the volume of S2O32- used in trial 2 is more than trial 1?
2.What is the use of Na2S2O3 (aq) in Part I?
Chemistry news on Phys.org
Well, the reaction is a classical one, with sufficient precision for most purposes. Hydrogen peroxide is the oxidant here, oxidizing iodide to iodine, which is very easy to observe from disappearance of brownish red color of iodine. In the second reaction, a radicalic coupling of two thiosulfate anions is present.
If you give more info about what trial 1 and 2, and also Part I mean, maybe we can be more helpful to you.
for part 1
Rinse a burette with deionized water and then with 0.05 M Na2S2O3 solution.
Record the initial burette reading in Table 1.
Pipette 1.00 cm3 of the ~0.8 M H2O2 solution into a clean 125 cm3 conical flask.
Measure 25 cm3 of deionized water with a 50 cm3 measuring cylinder. Pour it into the conical flask.
Measure 10 cm3 of 2.0 M sulphuric acid with a 10 cm3 clean measuring cylinder. Pour it into the conical flask.
Add 1 g of solid KI (record the exact mass) and 3 drops of ammonium molybdate catalyst into the conical flask.
Swirl the solution mixture until the KI dissolves.
Titrate the reaction mixture in the conical flask with the sodium thiosulphate solution until
it just turns pale yellow.
Add 3 drops of freshly prepared starch solution to the conical flask.
Continue to titrate the reaction mixture until it just changes from dark blue to colorless.
Record the final reading in Table 1.
trial 1 i got 31.2 cm3
trial 2 i got 33.4 cm3
i want to know why the reading of trial 2 is larger?
your difference in titrating seems to come from here; in trial 1, you may have determined the color change just on time, but in the second, you may have missed the point. It is generally recommended that you do a third final titration and calculate their average will give you the sufficient titer, okay for most purposes.
but all of my classmates got the same result...so i think the increase of the reading of trial 2 maybe not related to the problem you mentioned
um...will it related to H2O2?
Do you rinse the conical flack (erlenmeyer as we call it) after each trial? Any remaining iodine will cause a positive error. I recommend washing the flask with deionized water+thiosulfate+deionized water and drying prior to titration.
but...i used another conical flask in trial 2
i also want to know What is the use of Na2S2O3 (aq)??
Thiosulfate here is the unique reactant for iodine; with this, we indirectly find the moles of hydrogen peroxide. You have written the equations already. If you go back a bit, you'll see that all of them are inter-related.
Hi,
I have some questions on this matter too.. The labscript said that I don't need to calculate the concentration of H2O2 in mol/dm, but just use the volume of thiosulphate that i used in the titration.
Let say , i used 40ml of thiosulphate, and from the equation 1 mole of I2 react with 2 moles of thiosulphate. DOes it mean the concnetration of H2O2 is twice as the volume of thiosulphate or half of the volume of thiosulphate?thanks.
Neither. It means that you will need two moles of thiosulfate to react with one mole of I2. (moles=molarity*volume(L))
  • · Replies 0 ·
