| New Reply |
Questions about DDWFTTW |
Share Thread | Thread Tools |
| Jan2-12, 04:45 PM | #69 |
| Jan2-12, 04:54 PM | #70 |
| Jan2-12, 05:14 PM | #71 |
| Jan2-12, 05:38 PM | #72 |
The sail drag and lift can be further broken down into components either parallel, anti-parallel, or perpendicular to the sailboat velocity. The part of the sail lift that is parallel doesn't quite make sense though (at first), but I think there might be an account for the energy involved in doing that. I just don't agree that it comes from the wind though. I will now concede that in this there is a source of energy that would make for the illusion that the apparent wind can accelerate a sail craft in the opposite direction that it is blowing, so such likely has deeper origins in the energy in motion of the atoms and molecules of the craft itself. If this is indeed what is going at a deeper level, then I take back some of the things which I have said. It seems to me that if the matter's energetic motions were somehow deflected internally as a result of external pressure, then that deflection would be sufficient to explain the observational fact (which I have until now have downplayed) that indeed, as stated by A.T., that sailboats can "achieve a downwind VMG greater than true wind, steady state, on constant course, in constant true wind". If so, then some of this phenomenon could be related even to the General Relativistic corrections to Special Relativity (which drop the assumption of "inertial motion only"), as it appears that the fundamental microscopic non-inertial, vibratory/rotational motions involved must some how have changed course to some small degree (even though this is a non-relativistic scenario) as a result of the force interactions involved. Indeed, General Relativity would predict that the sailboat would undergo an additional "gravitational time dilation" due to the non-inertial motion induced by the deflection of both the apparent wind and the sail, which perhaps could be explain sometime in the future as increasing the effective internal wavelengths that result from "spreading" paths of highly-curvatured motions inside the mass of the sailboat over longer traces of distances with respect to the grid of "spacetime", consequently leading to a decreases in corresponding frequencies and thus decreasing the overall rate of time at the sailboat relative to an external observer. |
| Jan2-12, 06:02 PM | #73 |
JB |
| Jan2-12, 06:06 PM | #74 |
| Jan2-12, 06:12 PM | #75 |
| Jan2-12, 06:26 PM | #76 |
| Jan2-12, 06:28 PM | #77 |
Sailboats sail upwind all the time. They can leave a point downwind and readily arrive at a point directly upwind of where they were by simply sailing towards a point situation to the right (or left) of the upwind goal, and then once halfway there, they turn and sail directly towards that point. A: If taken literally and without context, your above quoted statement would make it seem as though you don't see how a boat can sail upwind such as the above. I'm pretty sure that's not what you mean but I do want to ask the question. B: If you believe boats can make upwind progress by sailing at an angle to the wind, but are having difficulty believing that *anything* wind powered can make steady state progress directly into the wind using basic Newtonian physics then I need to know that. A or B or other? Thanks JB |
| Jan2-12, 06:40 PM | #78 |
2 + (-2) = (3) + (-3)... etc. That makes it look like there is no mystery. What does not make sense to many still-skeptical skeptics is how would the Blackbird DDTWFTTW sand yacht conserve energy. Neither you, nor them, seem to have the explanation. Note that: (2)^2 + (-2)^2 is not (3)^2 + (-3)^2... etc. Would you mind explaining where the energy comes from to allow the wind to do work on the DDWFTTW vehicle (in the time between [itex]t[/itex] and [itex]t+\epsilon[/itex]) at the same time the DDWFTTW vehicle accelerates, with respect to the initial inertial frame of the vehicle at time [itex]t[/itex]? The work is done in opposite directions, conserving momentum even macroscopically, but not the kinetic energies of both (both increase as far as the initial inertial frame is concerned). My "very creative" resolution addresses this problem by bringing up the point about the true and factual existence of the below-macroscopic energy of atoms and molecules as being the entity that accounts for this apparent gap. My explanation is not that of a hidden net momentum, but a hidden set of vector momenta which sums to zero in the frame being evaluated (i.e. the momentum whose energy is identical to the rest mass of a body, as evaluated from the system frame in question, times the speed of light squared). I have a hunch that somehow this is either the static P-V energy that was already present in the air mass prior to vehicle operation, and/or the vibrational and rotational energy of the vehicle's particle makeup. Probably both. |
| Jan2-12, 07:29 PM | #79 |
The quote (taken out from a sentence after a comma) is taken too far out of context. It doesn't even relate to what I am saying. |
| Jan2-12, 07:35 PM | #80 |
Thanks. It appears that what you are saying the examples I have in that post can and do happen, you just don't believe they can be explained through simple Newtonian physics. Would that be a fair representation of your position? JB |
| Jan2-12, 07:36 PM | #81 |
Recognitions:
| Jan2-12, 07:56 PM | #82 |
The lack of significant mention of potential energy when discussing how tacking can allow sails to move ahead of the wind, in addition to the absolute absence of this point in many of the videos that I have seen that try to explain DDTWFTTW, has (I bet) contributed much confusion for people (including skeptics and naysayers) who wonder where the energy comes from and who, like myself, have for a time not been able to see how tacking would be of any benefit to it. |
| Jan2-12, 08:33 PM | #83 |
If by "potential energy" you mean something other than the mass of one fluid moving relative to another (or surface) and the kinetic energy contained thus, then the reason it isn't used in an explanation or video is that it would be flat wrong. There is NO other energy involved in accelerating the craft. If by "potential energy" you mean the mass of one fluid moving relative to another (or surface) and the kinetic energy contained thus - meaning the power of the wind, I can't imagine how you have missed such explanations. JB |
| Jan2-12, 08:42 PM | #84 |
Recognitions:
A sail can't generate thrust from an apparent headwind component, so it needs an apparent crosswind component which it diverts to aft of the boat's heading to generate thrust, which is why a sail boat needs to tack in order to acheive vmg downwind greater than true wind. |
| Jan2-12, 08:48 PM | #85 |
| New Reply |
| Thread Tools | |
Similar Threads for: Questions about DDWFTTW
| Ways to differentiate homework/textbook questions from regular questions | Forum Feedback & Announcements | 4 | ||
| DDWFTTW Circular Wind Tunnel Test | General Physics | 47 | ||
| Examination-Style Questions. Density of Material Questions (b)(i)(ii) | Advanced Physics Homework | 5 | ||
| If DDWFTTW is possible, would this be a viable application? | General Physics | 27 | ||
| DDWFTTW Turntable Test | General Physics | 1015 | ||
