New Reply
Coefficient of Friction
Share Thread Thread Tools
Dec28-11, 12:15 PM   #1
1.a block of mass 5kg moves on a rough horizontal plane with coefficient of friction (Dynamic) 0.2 under the action of a horizontal force of 30N. If the block starts from rest , find the distance it travels in the first 3 second.
2.a particle of mass 6kg,moving at 8m/s on a smooth horizontal surface, goes onto a rough horizontal surface with a coefficient of friction 0.25> Find the distance it moves across the rough surface before coming to rest.
3.This is my own question.Because I might get the concept of friction force wrongly
It's been in my mind for about 3 days thinking of it
A particle moving up a slope with a maintained speed of 1m/s
In another situation a same particle moving up the same slope with a maintained speed of 5m/s
Do the two particle use the same force?
As the Coefficient,mass,gravity,angle of slope are the same
2. Relevant equations
F/N =u(Mew)
F=ma
s=ut+1/2 at^2
Anyhow Regarding the equation,
Relating The Momentum and Force
F=ma
F=m x v/t
Ft=mv
So If The Force is 15N and the object moving at a constant velocity last for 3 seconds
Ft=mv
15(3) = MV
It will be 45 kg m/s ??
3. The attempt at a solution
1.
M=5kg
Force=30N
μDynamic = 0.2
μStatic = F/N (Force Used To Overcome the Static Friction)/(Normal Force)
= 30/(30x9.8)
= 0.1020
Initial Velocity=0
Final Velocity = 0
Time=3 seconds
Distance = Unknown
Untill This Step
What Should I Do With the two different coefficient of friction??
2.
Upon This Stage I Do Realize that I'm Getting Stupiddd
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec28-11, 12:38 PM   #2
Static friction is not an issue in this problem. Sum the forces and proceed either by impulse momentum or by Newton's Second Law and velocity-acceleration equation.
Dec28-11, 12:41 PM   #3
"A particle moving up a slope with a maintained speed of 1m/s
Do the two particle use the same force?"
Yes.
New Reply
Tags
dynamic friction, force, static friction
Thread Tools
Similar Threads for: Coefficient of Friction
Thread Forum Replies
Friction, Statics, Finding maximum angle and minimum coefficient of friction Engineering, Comp Sci, & Technology Homework 0
Finding Coefficient of Friction - Relationship b/w Normal Force and Static Friction Introductory Physics Homework 1
Friction problem with banked curve given static friction coefficient Introductory Physics Homework 3
Friction, Forces, Coefficient of Friction (True/False) Simple Introductory Physics Homework 2
low coefficient vs. high coefficient of kinetic friction General Physics 2
