Can x be equal to the square root of its own absolute value?
  • Thread starter Thread starter basil32
    Proof
The discussion revolves around proving the equality |x| = sqrt(x^2), exploring the properties of absolute values and square roots in the context of real numbers.
  • Conceptual clarification, Mathematical reasoning
  • Participants present various proofs and definitions related to the square root and absolute value, questioning the validity of their approaches and the necessary conditions for the proof.
Some participants have provided guidance on the definitions involved and the necessary steps to prove the statement, while others are exploring the implications of the definitions and what needs to be established for the proof to hold.
There appears to be an emphasis on understanding the definitions of square roots and absolute values, as well as the conditions under which the proofs are valid.
basil32
Prove that |x| = sqrt(x^2)
I've written two proofs but I don't know if they can be justified as real proofs or whether they are valid or not.
Proof 1:
[itex]\surd x^{2} = \surd \vert x \vert ^{2} = \vert x \vert[/itex]
Proof 2:
First Case ) Suppose [itex]x \geq 0[/itex] then [itex]\surd x^{2} = x = \vert x \vert[/itex]
Second Case ) Suppose [itex]x < 0[/itex] then [itex]\surd x^{2} = -x[/itex] where [itex]-x > 0[/itex] therefore [itex]-x = \vert x \vert[/itex]
Let's look at the definition of the square root:
If a2 = b and a ≥ 0, then a = √b. Now look at your problem. What two things do we have to prove?
That [itex]x^{2} \geq 0[/itex] and [itex]\vert x \vert \geq 0[/itex] ?
The two bolded things are what you want to prove. Once you have those, then the conclusion follows. Before you do anything, what is a in your problem? What is b? Once you have a and b, what is the first thing you need to prove?
[itex]a = \vert x \vert[/itex] and [itex]b = x^{2}[/itex]
[itex]a^{2} = \vert x \vert ^{2} = x ^ {2} = b[/itex]
[itex]a = \vert x \vert[/itex] which is nonnegative. correct?
Correct.
  • · Replies 21 ·
  • · Replies 23 ·
