Volume of Isosceles Right Triangles with Base of x^2+y^2=9
  • Context: Undergrad
  • Thread starter Thread starter Physicsisfun2005
    Base Triangles Volume
The volume of the solid with a base defined by the equation x² + y² = 9 and cross sections that are isosceles right triangles is calculated using the integral π∫ (4.5 - 0.5x²) dx from -3 to 3. The area of each triangular cross section is derived from the base length of √(9 - x²). Upon solving the integral, the final volume is confirmed to be 18π, validating the approach and calculations presented in the discussion.
  • Understanding of integral calculus
  • Knowledge of geometric properties of isosceles right triangles
  • Familiarity with the equation of a circle in Cartesian coordinates
  • Experience with definite integrals and their applications in volume calculation
  • Study the derivation of the area of isosceles right triangles
  • Learn about volume calculations using cross-sectional areas
  • Explore applications of integration in finding volumes of solids of revolution
  • Investigate the properties of circular regions and their applications in calculus
Students in calculus courses, educators teaching geometric applications of integrals, and anyone interested in solid geometry and volume calculations.
Physicsisfun2005
I don't have the answers in the back of my book and I really want to know if i did this correctly since its graded. the Problem is: Let the region bounded by [tex]x^2+y^2=9[/tex] be the base of a solid. Find the Volume if cross sections taken perpendicular to the base are isosceles right triangles.
i know a triangle is [tex].5bh[/tex] and the base of it will be [tex]\sqrt{9-x^2}[/tex] so for volume the final answer is [tex]\pi\int 4.5-.5x^2 dx[/tex] with the limits from -3 to 3 and i get [tex]18\pi[/tex] for volume.....is this right?
Don't post the same thing in more than one forum!
Yes, your approach and final answer are correct. To find the volume, you need to integrate the area of the cross section (isosceles right triangle) over the range of x values from -3 to 3. This is represented by the integral \pi\int 4.5-.5x^2 dx. When you solve this integral and plug in the limits, you get 18\pi as the volume, which is the correct answer. Good job!
9K
