| Thread Closed |
KE of system / different reference frames question |
Share Thread |
| Jan3-12, 11:20 AM | #52 |
Mentor
| Jan3-12, 11:23 AM | #53 |
Mentor
Earth loses 100 kJ KE Car gains 50 kJ KE Battery gains 50 kJ electrochemical energy All energy is accounted for. There is no missing energy 50 kJ + 50 kJ = 100 kJ, if you don't believe me then get a calculator and confirm. Why don't you ponder that a bit until you get it. |
| Jan3-12, 11:35 AM | #54 |
iΔpc*vf,c = -10000kg.m/s*10m/s = 100000 kg.m2/s2 = -100kJ |
| Jan3-12, 11:40 AM | #55 |
The above says that in the second case, there will be both charge in the battery and kinetic energy. A clear violation of both the conservation of momentum and energy. All the result of one arithmetic error, that has been flagged to your attention. Δpc*vf,c = -10000kg.m/s*10m/s = 100000 kg.m2/s2 = -100kJ |
| Jan3-12, 11:50 AM | #56 |
I should clarify something which most people interested in physics will not be familiar with. What Humber means when he says "a calculation confirms an error" is not that an error was made in the traditional sense, like incorrect math or a logical inconsistency. He simply means that the result conflicts with his preconceived expectation of what the result should be. So it is wrong.
| Jan3-12, 11:56 AM | #57 |
The correct solution to this problem, when the juvenile runs out of excuses, and recognizes his error, relies on nothing more than the conservation of momentum, which is a law quite independent of frames.
There are only two bodies involved: the car and the Earth so, a very simple case. When the car slows, it changes momentum; Car gains momentum -p Earth gains momentum p p^2/2m = p^2v^2/2m = 1/2mv^2, which is the familiar KE equation. The car loses KE = p2/2mcar The Earth gains KE = p2/2mearth The total energy is therefore; p2/2mcar+ p2/2mearth Because mearth is very large ,~6e24kg, the second term is negligible and can be approximated to the first term. Initially, all of that energy will have come from the fuel of the F1 car, and in part, like the consumer counterpart, KERS is intended to reduce fuel consumption by returning energy that would otherwise be lost. In a conventionally braked vehicle, the KE of the car's mass is dissipated as heat in the brakes. KERS does not affect momentum transfer to the ground, but stores the KE that is otherwise lost to heat. That energy may be transferred to a flywheel; The angular momentum L, of a particle, and the moment of inertia, I L = r.p = r.mv L =I.ω KE = 1/2.I.ω2 In the given example of a 1000kg vehicle braking to a stop from 10m/s, and where the mass of the Earth is 1e25kg, the energy transferred to the ground is; (100000kg.m/s)^2/2e25kg = 5e-18J There is no significant transfer of energy to or from the F1 car and the ground as a result of KERS. The conservation of momentum says that result is independent of frame. |
| Jan3-12, 12:16 PM | #58 |
The following calculation shows that there is negligible transfer to the ground, and is in agreement, also producing 5e-18J
[itex]p_{i,c}=m v_{i,c}=10000 \ kg \ m/s[/itex] [itex]\Delta p_c=f_c \Delta t= -10000 \ kg \ m/s[/itex] [itex]p_{f,c}=p_{i,c}+\Delta p_c = 0 \ kg \ m/s[/itex] [itex]v_{f,c}=p_{f,c}/m= 0 \ m/s[/itex] [itex]KE_{i,c}=1/2 m v_{i,c}^2 = 50 \ kJ[/itex] [itex]KE_{f,c}=1/2 m v_{f,c}^2 = 0 \ kJ[/itex] [itex]p_{i,e}=M v_{i,e}=0 \ kg \ m/s[/itex] [itex]f_e=-f_c=1000 \ N[/itex] [itex]\Delta p_e=f_e \Delta t= 10000 \ kg \ m/s[/itex] [itex]p_{f,e}=p_{i,e}+\Delta p_e = 10000 \ kg \ m/s[/itex] [itex]v_{f,e}=p_{f,e}/M= 10^{-21} \ m/s[/itex] [itex]KE_{i,e}=1/2 M v_{i,e}^2 = 0 \ kJ[/itex] [itex]KE_{f,e}=1/2 M v_{f,e}^2 = 5\;10^{-18} \ J[/itex] All that remains, is to show that result is independent of frame. Frame independence for the result can be shown by the introduction of an observer, moving relative to the Earth and Car at velocity u. m = mass of car ΔKE(car) = (−m u − p)^2/2m − (−m u)^2/2m = (m^2 u^2 −2m u·p + p^2)/2m − (m^2 u^2)/2m = −u·p + p^2/2m M = mass of Earth. ΔKE(earth) =(−M u + p)^2/2M − (−M u)^2/2M = (M^2 u^2 + 2M u·p + p^2)/2M - (M^2 u^2)/2M = u.p + p^2/2M The total energy is once again p^2/2m + p^2/2M |
| Jan3-12, 07:31 PM | #59 |
Mentor
If some object gains momentum Δp then [itex]p_f=p_i+\Delta p[/itex] Dividing both sides by the mass m we get [itex]v_f=v_i+\Delta v[/itex] Substituting that into the expression for the object's final KE we obtain [itex]KE_f=\frac{m}{2} v_f^2 = \frac{m}{2} (v_i+\Delta v)^2 = \frac{m}{2} (v_i^2 + 2 v_i \Delta v +\Delta v^2) = KE_i + v_i \Delta p + \Delta p^2/2m [/itex] [itex]\Delta KE = KE_f - KE_i = v_i \Delta p + \Delta p^2/2m [/itex] This is different from what you wrote because of the [itex]v_i \Delta p[/itex] term. Your neglecting that term is actually your key conceptual error, so I do hope you spend some time examining the brief derivation. If the object is particularly massive, like the earth, then the [itex] \Delta p^2/2m [/itex] term drops out, but the [itex]v_i \Delta p[/itex] term does not. |
| Jan3-12, 07:33 PM | #60 |
Mentor
| Jan3-12, 07:42 PM | #61 |
Mentor
| Jan3-12, 07:45 PM | #62 |
Mentor
| Jan3-12, 07:50 PM | #63 |
Mentor
I love the arrogance of the ignorant. Keep it coming Humber, it is very amusing. |
| Jan3-12, 08:11 PM | #64 |
= (10000kg.m/s)^2/2*1e25 = 5e-18J |
| Jan3-12, 08:19 PM | #65 |
Mentor
| Jan3-12, 08:20 PM | #66 |
When you finish falling over yourself and the arithmetic churn, you can stop. |
| Jan3-12, 08:25 PM | #67 |
Mentor
Do you agree with the derivation in post 59?
If yes, then do you understand how it was your key mistake? If no, then which specific step of the derivation do you believe is in error, and what do you believe is the error? |
| Jan3-12, 08:27 PM | #68 |
| Thread Closed |
Similar discussions for: KE of system / different reference frames question
| Noninertial Frames of Reference Question | Introductory Physics Homework | 1 | ||
| Kinetic Energy of Objects in System, in different frames of reference. | Classical Physics | 3 | ||
| Frames of reference question | Introductory Physics Homework | 0 | ||
| reference frames question | General Physics | 2 | ||
| Frames of Reference Question | Special & General Relativity | 3 | ||
