New Reply
Controlling a material's opacity
Share Thread Thread Tools
Jan5-12, 01:44 AM   #1
So I'm a sophmore in college working on a project, and I am stumped. The problem is this:
I need to be able to control the opacity of some normally transparent material. So for example, I would have a transparent object sitting on the table, and when I shine a UV laser or an IR laser through it, the part that the laser is passing through of it becomes translucent, or any part of it becomes translucent. Another possibility would be if I applied a magnetic or electric field through the material, it would become translucent. The color it turns when it loses it's transparency would preferably be white or some light color. It must be able to change to translucent rapidly, to the degree of several nanoseconds, ~(10^-9 - 10^-7)s. And yes, it must be able to change back to transparent just as quickly.
If anyone has any relevant information, including even the name of the property of material to adjust opacity, it would be greatly, greatly appreciated.
Thank you for your time!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan5-12, 04:17 AM   #2
Recognitions:
Homework Helper Homework Help
Photoreactive materials perhaps?
You can also use magnetic fields to line up polarizing crystals in a material.
You can put a liquid crystal between two crossed polarizers - like in an LCD display - apply a current and the crystal changes the rotation of the light passing through it.
That sort of thing?
Jan5-12, 04:35 AM   #3
Recognitions:
Gold Membership Gold Member
Quote by Simon Bridge View Post
That sort of thing?
They are possible solutions but I think not for someone with limited means. The principles were well known but need high voltages (Kerr Cell) or high tech (LCD) to implement.
You can buy thermochromic paints and dyes which react slowly to heat. You could focus an IR beam on the table to produce a spot, perhaps. But I'm not sure whether such dyes would go transparent at low temperature. Try googling the term.
Jan5-12, 05:51 AM   #4
Recognitions:
Well I haven't seen any constraints - perhaps OP is just looking for something that can be looked up and read about - maybe write an essay?
I also thought of just having three stacked polarized sheets - cross the top and bottom one and put the middle one on an armature run off a motor or whatever so it rotates when an electric field is applied.
Fits the description but would probably be cheating.
New Reply
Tags
material opacity
Thread Tools
Similar Threads for: Controlling a material's opacity
Thread Forum Replies
Opacity and Spectral Features Biology, Chemistry & Other Homework 1
Opacity and Insulation Introductory Physics Homework 1
Opacity (fundamentals) Classical Physics 15
Stellar Opacity Power Law Introductory Physics Homework 0
