Compute genus via Riemann-Hurwitz and monodromy
  • Thread starter Thread starter jackmell
The discussion focuses on calculating the genus of the algebraic curve defined by the equation w^5 + w^2 + z^2 = 0 using the Riemann-Hurwitz formula. The user, Jack, attempts to apply the formula, identifying the degree of the mapping as five and the genus of the complex plane as zero. However, he struggles with the computation of the sum related to the monodromy group and the ramifications at branch points. Ultimately, the correct genus is determined to be one, confirming that the surface is topologically equivalent to a Riemann sphere with one handle.
  • Understanding of Algebraic Geometry concepts, specifically Riemann surfaces.
  • Familiarity with the Riemann-Hurwitz formula and its application in genus calculations.
  • Knowledge of monodromy groups and their role in analyzing branch points.
  • Basic proficiency in complex analysis, particularly with algebraic curves.
  • Study the Riemann-Hurwitz formula in detail, focusing on its applications in algebraic geometry.
  • Learn about monodromy groups and their significance in determining the behavior of algebraic functions around branch points.
  • Explore the construction of Riemann surfaces from algebraic curves, particularly through examples similar to w^5 + w^2 + z^2 = 0.
  • Investigate the implications of genus in algebraic geometry and its relationship to topological properties of surfaces.
Students and researchers in Algebraic Geometry, mathematicians interested in complex analysis, and anyone looking to deepen their understanding of Riemann surfaces and genus calculations.
jackmell
Hi guys,
I new to Algebraic Geometry and was wondering if someone could help me with this problem:
Given the algebraic curve [itex]w(z)[/itex] represented by [itex]w^5+w^2+z^2=0[/itex], show that the genus is one by employing the Riemann-Hurwitz formula.
For the mapping [itex]f:X\to S[/itex], the Riemann-Hurwitz formula is given by:
[tex]2g(X)-2=\text{deg}(f)\left[2g(S)-2\right)+\sum (e_w-1)[/tex]
which I assume the expression [itex]f:X\to S[/itex] as applied to my problem can be written as [itex]w(z):\mathbb{C}\to S[/itex], that is, the function w(z) maps the (five-sheeted) complex plane to the Riemann surface given by [itex]S[/itex] and it is this surface that is topologically equivalent to a Riemann sphere with one handle thus having genus one. If that's not the correct way to state that, could someone correct that for me please?
I believe I understand somewhat well, direct construction of the Riemann surface given by the expression [itex]w^2-p(z)=0[/itex] and the subsequent determination of its genus directly from the union of two Riemann spheres. However I'm not able to deduce that via Riemann-Hurwitz.
But back to the problem above:
I'm taking [itex]g(X)[/itex] to be the genus of the complex plane which is zero.
The degree of [itex]f[/itex] I'm taking to be the highest degree of [itex]f(z,w)[/itex] in [itex]w[/itex] which is five.
The sum is where I'm having the problem. This I believe can be computed from the monodromy group which I assume represents the ramifications around each branch-point which I take to mean the branching around each branch-point including infinity. Here's my analysis of that:
The function has six finite branch points and the surface [itex]S[/itex] ramifies around each one as a two-valued branch and three single-valued branches. I think each monodromy group about these branch-points can be written in terms of [itex]\left\{(n,m)\right\}[/itex] with [itex]n[/itex] being the sheet number and [itex]m[/itex], the branch order as:
[tex]((1,2),(3,1),(4,1),(5,1))[/tex]
Maybe though that's not a valid way to write that. However, around the branch-point at infinity, the function ramifies into a single five-valued branch so the monodromy group is [itex]((1,5))[/itex]
So my (incorrect) analysis of the sum would be [itex]\sum (e_w-1)=(2-1)+(1-1)+(1-1)+(1-1)[/itex] for each finite branch-point and [itex]\sum (e_w-1)=5-1[/itex] for the point at infinity. Plugging all this into the Riemann-Hurwitz formula I obtain:
[tex]-2=5\left[2g-2\right]+10[/tex]
and solving for g I obtain [itex]g=-1/5[/itex] which is obviously not correct.
I don't know, maybe I'm not even qualified to even ask the question. Still I would like to see how it's solved at the very least if someone could help me with that and as I study more the subject, I'm sure it will come together eventually for me.
Thanks,
Jack
Let [itex]f(z,w)=z^2+w^2+w^5[/itex]
then it's much easier to compute it via the formula:
[tex]p=\sum_{i=1}^M \frac{r_i-1}{2}-n+1[/tex]
with [itex]n[/itex] the degree of the function and [itex]r_i[/itex] the ramifications over each critical point including infinity.
The finite critical points are zeros to [itex]R(f,f_w)=0[/itex] where R is the resultant since the function has no poles. There are seven critical points, one of which is the origin. At the origin, the function splits into five single-cycles. At the other six, it ramifies into a 2-cycle and three single cycles. At infinity, it fully ramifies into a 5-cycle. So then we have:
[tex]p=\sum_{i=1}^8 \frac{r_i-1}{2}-n+1=1/2(1+1+1+1+1+1+4)-5+1=1[/tex]
  • · Replies 26 ·
