Determine the magnitude and direction of smallest force
The problem involves determining the magnitude and direction of the smallest force required to move an oil drum, given that the resultant of three forces must equal 500 N. The subject area includes vector forces and equilibrium conditions.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to use equations for the summation of forces in both x and y directions, but notes a challenge with two missing variables. Some participants suggest combining the given forces to find a more efficient direction for the applied force.
The discussion is ongoing, with participants exploring different interpretations of how to approach the problem. There is a suggestion to visualize the forces to determine an efficient direction for the smallest force, but no consensus has been reached yet.
The original poster references a specific figure that is essential for understanding the problem setup, which may not be accessible to all participants. Additionally, the requirement for the resultant force to be exactly 500 N adds a constraint to the discussion.
blackandyello
To move the oil drum, the resultant of the three forces shown must have
a magnitude of 500 N. Determine the magnitude and direction of the smallest
force F that would cause the drum to move.
here is the figure: http://screensnapr.com/e/yliMVN.png
summation of x forces = 0 - 300 * cos25 + F cos (p)
summation of y forces = 250 - 300 * sin 25 + F sin (p)
i tried using those 2 equations and put it in
R ^2 = x ^2 + y ^2 (phytagorean theorem for resultant)
but i ended with 2 variables missing which is F (magnitude) and p(direction). Any insights? Thanks
Take the two forces given and combine them to give a single net force, draw that in and you should be able to find a direction which uses your force the most efficiently :)
when we say most efficiently? u pertain that it has to be in the same direction as the resultant?
yep, you got it.
  • · Replies 16 ·
  • · Replies 18 ·
