Find the Angle for Maximum x Position in Free Fall Motion
The discussion focuses on determining the angle of inclination, [theta], that maximizes the horizontal position (x1) of a particle in free fall motion, given initial conditions such as initial velocity (v0) and initial height (y0). The equations of motion are established, leading to the expression for x1, which incorporates the time (t1) at which the particle reaches the ground (y=0). The differentiation of x1 with respect to [theta] yields a complex equation that does not present an obvious solution for [theta], indicating the challenge in deriving a simple formula for maximum x1.
  • Understanding of projectile motion and kinematics
  • Familiarity with calculus, specifically differentiation
  • Knowledge of trigonometric functions and their applications in physics
  • Basic grasp of the quadratic formula and its use in solving equations
  • Explore advanced projectile motion concepts in physics
  • Learn about optimization techniques in calculus
  • Study the application of trigonometric identities in motion equations
  • Investigate numerical methods for solving complex equations
Students and professionals in physics, mathematicians, and engineers interested in optimizing projectile trajectories and understanding the dynamics of free fall motion.
agro
Consider a particle located at (x0, y0), having inital velocity v0, and the angle of inclination of the velocity vector is [the]. The particle is subjected to a vertical acceleration of -g. It's equation of motion is...
x = x0 + v0*cos[the]*t
y = y0 + v0*sin[the]*t - 0.5*g*t2
If t>0, the particle will reach y = 0 when
t = {v0*sin[the] + sqrt((v0*sin[the])2+2*g*y0)}/g
(found using the abc formula)
If we call the time t1, then at that time the x position of the particle is (call it x1)...
x1 = x0 + v0*cos[the]*t1
The question is: at initial height y0, what angle will make x1 maximum?
I found it very hard to make the equation simple enough to be able to solve this problem... Can anyone help me?
PS: in the case of y0 = 0, the problem will be easy to solve, with the answer 45 degrees.
Thank you...
Replacing t1 in x1= x0+ v0 cos[theta] t1
with t1= (v0/g)sin[theta]+ (1/g)(v0^2 sin^2 [theta]+ (gyo/2))^(1/2)
(the positive time at which y= 0) gives
x1= x0+ (v0^2/g)sin[theta]cos[theta]+(v0/g)sin[theta](v0^2sin^2[theta]+ (gy0/2))
Differentiating,
dx1/d[theta]= (v0^2/g)(cos^2[theta]- sin^2[theta])+ (v0/g)cos[theta](v0sin^2[theta]+(gy0/2))^(1/2)+ vo^3/g sin^2[theta]cos[theta](v0^2sin^2[theta] + (gy0/2))^(-1/2) = 0 at maximum x1.
I'm with you! I don't see any "nice" way of solving that for [theta]. Do you have any reason to think that there should be?
  • · Replies 29 ·
10K
